Hi all.
Hope someone may be able to offer some advice regarding a problem I seem to have with my fridge in the caravan I've just bought.
The fridge is a 3 way electrolux 123e. The caravan is a 1994 freedom microlite, so I assume the fridge is the same age. I have attempted to run the fridge through the mains, and freezer tray is getting cold so I assume it is working ok from the refrigeration side. However when I turn it on it, the red on switch flashes on and off like an indicator and makes an intermittent high pitched noise. I left it for a few hrs, and ithe problem remains. It also happens when I use the 12v supply. Ive not tried the gas yet.
Any suggestions as to what may be causing the problem will be appreciated.
Andy
Andy
