Front window scratches removal
What do you boys use to remove front window scratches? Was thinking on T-Cut, but thought I would consult the wise and wonderful on here.
Fenwicks window wise, or Vuplex ( which is great at hiding the fine ones)
Mel (definitely wonderful, not sure about wise and absolutely not a boy😉)
There are a number of good plastic window polished for removing scratches. Use a dedicated one to ensure the chemicals don’t interact with the plastic. I used Fenwicks which worked well. Needs patience; slow and easy.
Do not bring T cut anywhere near a caravan as it is too abrasive. We use Vuplex for removing fine scratches. For a deep scratch use Brasso pads then the Vuplex.
