Full Awnings to fit size 775 - Help & Advice Please!
May 15, 2005
215
hi there, A friend of our who is new to caravanning is looking for a full awning, his awning size when measured ground to ground on a flat concrete surface measured 775 cm. However after looking around most awnings tend to have a size stop at 775 and another start from 775. Which would you go for? our local dealer wasn't much help and said he could not get one, as it would either fit to tight or to sloppy on those sizes. Are there any awnings out there that straddle this size making a good fit? Other problem we have is it needs to be in the cheaper end of the market for cost! He already has a porch awning, so that is not realy an alternative, it's more if he can get a full awning or needs to stay with his porch. Look forward to your replys. Many Thanks
depending what awning you are buying,manufactures have a sizing chart.you'll find that these charts size awnings differently.bradcot, if you look at their website have a size that fits inbetween your requirement size 780 (766 cm-795 cm).
most manufactures give a similar amount of leeway either side.
SIZE 780 = 15 cm either way (BRADCOT SIZING)
SIZE 750(763)775 SIZE 775(788)800 IS APP 13 CM EITHER WAY
SO IF YOUR AWNING IS 775,YOU CAN OPT FOR A TIGHT FIT OR LOOSE FIT.personally i would go for neither,go for a manufacturer with an inbetween size like bradcot or a similar manufacture with similar sizings
