We have FTTC and use Plusnet - all good at around 60 down, 20 up. But we recently received a flyer from a company who are going to be running FTTP around our village with significantly faster connection. Getting the cable to the house is not really a problem but I worry about wat happens inside the house. Currently our master socket is in a cupboard under the stairs, in the middle of the house. All rooms in the house are wired for Cat6 and coax and it all terminates in this cupboard, from where I can patch it however is needed. I therefore need any modem and router to be in here. I will not accept cables tacked to skirting boards or run in external trunking. What is the internal installation for FTTP like? I guess I could have the modem/router in the front room and then use the Cat6 connection from there to the under-stairs cupboard for onward distribution, but this seems a bit sub-optimal.
If they bring FTTP they will put a fibre termination on the outside of your house
I
Finally, make sure you have the fibre installed and tested BEFORE you cease your existing line else you will loose your existing number. Get that moved onto the FTTP circuit then cease the line. The fibre router should have a PSTN socket for your phone(s).
I am a little worried about my land line number. When I agreed with Vofafone they said they has secured my number. But now, due to the delay in getting my fibre up and running, I will be in limbo, between providers, until my contract starts with Vodafone.
This is what I believed. I think if I go this route I can have the ONT in the front room (which has an outside wall to the front of the house with easy routing across the lawn), then plug it into an Ethernet port in that room which will go to my βnetwork cupboardβ where I can house the router. From there I can then use the Ethernet ports on the router plus a network switch (which I already have) for Ethernet distribution around the house.I don't think that's correct at least not what BT do.
The fibre runs up to the house and through the wall. Inside there is a small box known as an ONT.....optical network terminator. This is where the fibre is terminated and the optical signal converted to an electrical signal. A Cat6 cable goes from the ONT to the router.
You need mains power for both the ONT and router
I canβt run any cables, thin or otherwise, under carpets etc as most of the floor area downstairs is uncarpeted. The whole reason I had Ethernet run throughout the house when we renovated it several years ago was to avoid having cabling run around the place. Same goes for the exterior - no visible aerial, satellite or EV charger cables; all run directly into the house and are run in walls or through roof voids. I canβt stand visible cabling!
I may well be out of touch with what "Joe public" is up to and requires in respect to internet data speeds, but what are the real-life benefits to this particular audience, ie the normal house holder, of these super speeds?
We bumble along at achieved 70/75 mbps down and 20 up, and have no perceived issues with bottle necks of our own making, many websites we visit can be themselves slow to react; investing in a faster home connection I can't see helping there.
I can see a value within a household of many users who simultaneously are into very high bandwidth requiring pursuits.
Certainly, since they went to fibre to the cabinet a few metres up the lane and replaced my aluminium wire with a cable, reliability stepped up a league, so I can see reliability could be a driver for optical transmission.
Presently I have resisted the seduction coming from my provider to pay for something faster, as I can't yet see the benefit to us.
One reason we keep the landlines is emergency calls as our mobile signal is dire. We can use mobiles with WiFi calling but if power is out we then have an old style plug in telephone to fall back on. Just have to see what tge change over to VOIP brings. But being old and vulnerable may get us battery back up, but I might look out to some old ex MOD signal lamps or semaphore flags.One additional point that I've made before.
Wired connections are going to be phased out in about 3 years (but knowing how BT works could be 30 years π )
This means we'll all have to switch over to Digital Voice or Voice over IP. The one problem you have to consider with this is if there's a power cut or your broadband goes down you wont be able to make a phone call - even and emergency call.
If you have a good mobile signal this may not worry you but we don't and often when there's a power cut the poor mobile signal disappears completely.
Ofcom recommend the Communication Providers supply battery back up units to those in vunerable areas. Good luck with that. We had to argue with BT for many months before we got ours. And such is BTs wonderful organisation we got 5 when we only need 2. One for the ONT and one for the router.
We bought this house as a total wreck - the whole house was renovated from floor to roof, along with a couple of extensions and internal restructuring. I designed it all, including what utilities to have and where. As a consequence I know where all the wires go and there's always a plug near where I want one. Every habitable room has at least 2 Ethernet and 2 coax sockets, with heavy use areas like the lounge, living room and office having 4 Ethernet points each. The satellite dish cabling runs straight through the wall behind the dish into the roof void and ultimately to the network cupboard. We have no aerial. The only external cable at all that is tacked to the wall is a short section of the current phone/broadband copper wire that runs along the front of the house at low level for a couple of metres before heading inside.Since we moved into this house just over three years ago I have removed so much interior and exterior cabling it is hard to know what the previous owners did with it. Some bedrooms would have three power sockets all together and then a couple more elsewhere in the room for good measure. two telephone lines with extension running havens knows where, sat and terrestrial cables. All now removed and holes in walls filled, and skirtings made good. I use wifi around the house with TP-Link extenders, plus two mobile land lane phones. Tv is on satellite so just the two cables into the lounge and straight into the back of the TV.
Ethernet and wifiHow is your TV connected? By WiFi? This may be the bottleneck.
