I'm booked onto a serviced pitch soon for the first time. Having used the normal Wastemaster and AquaRoll what else would I need? We haven't got an inbuilt water tank if that makes any difference.
Amazing how close the Y and the T, is on the keyboard.I would echo, Rob-T's comments. I would also wonder why it's taken you this long, to book a fully serviced pitch in the first place L.B.
Your caravan really is like a hotel apartment, once it is fully hooked up. I wouldn't recommend it for anyone else, mainly because I don't want you lot booking up all the serviced pitches before I get the chance to.
As Rob-t says, it all depends on your usage as to what equipment you need. If your only going to use full hookup once in a blue moon, don't bother with buying anything. the fact that you don't have to walk miles (OK, yards) to fill and empty water is often good enough to make your holiday all that more relaxing. On the other hand, if you plan to use them, say at least once a year, for the main hols then get kitted out.
We bought the aqua roll mains adapter, because it looked like the best way to connect water to the caravan. You can however get a water pipe that fits direct from the pitch tap and onto your caravan (no water pump needed). This will save you having to take your aqua roll with you but on site water pressure may not be ideal for your usage. Incidentally, you may need a water pipe extension if you have a long caravan as the tap isn't always in the most convenient spot. Have a look on Ebay for the aqua roll fitments (search for mains, water, caravan)there seems to be a few "other make" adapters for sale with prices that won't scare your wallet.
It's a similar story for your waste water, if your going to use fully serviced pitches, but a long piece of waste pipe, it depends on where your outlets are on the van as to how long your going to need it, but a "T" piece and use two small lengths of pipe that will connect into one, this way you only need the one length of extra long pipe (teaching Nan's to suck eggs, springs to mind).
Sometimes a pitch may come with a TV booster point, so you may need a long aerial lead that you can run through a window. You may have a connection point already, my old ABI did.
Apart from that, you'll need an extra large fridge. That's to store more beer because you now have more time on your hands and need something to fill it with.
Hope this helps.
Hehheh! ;OPLets get this straight. Politicians and the old boys in the upper house just love to make out like the've roughed it for a few days so they can make out like they know how the bulk of the population have to cope.
Lord B is obviously at the limit of his tether living a basic existance in his regal caravan and now making out like he needs help and advice with the next stage of his social experimentation.
Get real Lol the closest his lordship is going to come to a few beers is doffing his cap at a local tavern for a 1/2 of real ale with the "locals" before scurrying back to the caravan for a Dartington cut Glass Tankard of lightly chilled 86 or 2001 Chateau d'Yqem ;-)
My liege. I'm honoured to be able to keep the proles up to speed with your tireless work to benefit your colleagues knowlege in the upper house ;-)Lets get this straight. Politicians and the old boys in the upper house just love to make out like the've roughed it for a few days so they can make out like they know how the bulk of the population have to cope.
Thank you all, I've just done a search on EBay after seeing the Aquaroll Adaptor kit was almost
Rob, I agree, a second cap is better really.Damian,
You're right in what you say about making your own mains adaptor but I would suggest buying a spare cap for the aqua roll rather than drilling thru existing one. That way when on non serviced pitch the aqua roll can be used on its own.
Robert
Hi Lord B
Slightly off the original topic. Last night I bid on a used wastemaster on ebay. I've seen them priced at around
