Fusebox location/water issues/Abbey Freestyle 550 SE
Sep 4, 2024
22
8
Hi.
|'m getting no water into my Abbey Freestyle 550 SE (2005). Pump light comes on, nothing, I've used a different pump and ruled that out. Connections all look sound. Replaced recently the NRV but that is the right way around and appears okay. I want to check the fuses next. WHERE IS THE FUSEBOX IN THIS THING??? I've looked everywhere for the last hour. I mean the actual box with the fuses in, not the control switches.. It must have one.
Any help with getting the water to work or finding the fuse box is very welcome. I will need a little bit more specific information that "somewhere near the door usually" which is all I could gleem from Google.
Thanks in advance
8,649
Often fuses can be sited under lounge seat right forwards and attached sometimes to the front bulkhead. Delightfully easy to access and read.
Sep 4, 2011
447
237
18,935
Around that year it will be a Nordelettronica unit and if your layout has a low cabinet to stand Tv on they are often inside it or some models in wardrobe.
Apr 23, 2024
345
273
935
in the wardrobe is another place , and with older ones in the wardrobe underneath the baseplate , which lifts out to reveal the rear of the fire and the fuses bolted to the external wall of the caravan , which you will need a pair of binoculars and Mr Gadgets long reach arms to see and get to!!!
