FWD or RWD ?
Apr 19, 2005
32
I have only ever used FWD cars for towing - a manual VW Passat and an auto Volvo V70 - both have been fine on the road, but I've had a problem or two pulling the caravan (Lexon EB) of a wet pitch. The front wheels spin. With the Volvo this can be reduced by selecting winter mode. The only RWD car I've owned was the MGF, but no chance trying a caravan with that. Are there any advantages for caravanning in using an RWD car?
I'm sure 4WD drive is best, but don't want a 4X4 and I'm not keen on the XC70 or Audi Allroad.
Thanks,
Tillman
909
If traction is your problem, then RWD is the next best thing to 4x4.
Nov 6, 2006
239
As Lutz says, RWD is next best after 4*4, but only when the 'van is on the hitch. In all other slippery circumstances, RWD is "pants" in my opinion.
909
I take it you are referring to towing on surfaces where traction may be a problem (grassy sites, snow/ice, etc.). Otherwise, there is little to choose between RWD and 4x4.
Apr 19, 2005
32
I'm OK with RWD vs FWD for 'normal' use, it's the traction aspect when towing a caravan I was enquiriing about, particularly when pulling on a wet, grassy pitch. From the comments so far, it would seem that RWD has the edge over FWD, under these circumstances.
Cheers,
Tillman
