Gas Again please help
I am taking our van away tomorrow, I am thinking of changing from Buntane (Blue) to Propane (Red), if I change regulators, is that all I have to do? PLEASE HELP Liz
Liz, if you have the new bulkhead mounted regulator, it is just a case of changing pig tails.
If you have the older style regulator (NOT fixed to bulkhead), just change the regulator and make sure you have the right one to fit the Propane cylinder
I wouldnt be happy with it either Liz. the battery should gas off as this is a byproduct of charging a lead acid battery but it should NEVER boil. Take it back and get the dealer to fix it properly before you have a real problem. Should the vented gas blow back into your van through vent etc then you could have an explosion on your hands.
Don
