- Jul 18, 2017
- 16,925
- 5,505
- 50,935
We are not fans of gas BBQs however we have purchased a Campingaz Attitude 2Go gas BBQ to use during the winter months as we can also use it in the conservatory area. It comes standard with the hose that can be attached to a CV470 gas cylinder.
However each cylinder lasts about 2.5 hours so can work out expensive. I want to remove the current hose and fit a new hose with a connector for it to clip onto the gas connector on the side of the caravan. I assume that this should not be an issue as the pressure is regulated. However I also thought of having an additional connector with a short hose with a Butane connector for use at home.
So from gas BBQ when using at home the hose with the coupling connector for the caravan. Then if I want to use it at home using the butane bottle I connect it to the coupling that has the butane connected on it.
Do you think this is feasible as using circlips to make sure there are no gas leaks?
Links to the same picture removed . There is no need to link 4 times to the same picture.
