Mar 21, 2008
364
If you are able to get another if it runs out then a 3.9kg will be fine.
I think most people use the 6kg size - I carry two.
If you're going away for a week with hook-up then you won't use much gas - only for cooking.
If you don't have hook-up you will use lots of gas - cooking, hot water and fridge.
If you don't have hook-up you will use more than 3.9kg in a week.
We went away for a week last summer and used about 6kg.
Hope this helps.
Jun 17, 2011
826
27
18,885
Main factor is nose weight. If you are near the limit stick with 3.9 of look at the light cylinders.
