gas butane///propane
Jun 13, 2025
10
Morning all,
Thought better to post here rather than start a new topic, albeit this one is dated it’s the same sort of question.
This is the connection I have in our ‘new’ old van. It’s a 2005 Lunar Quasar. The previous owner used 4.5kg butane. I have some 6kg propane but want to check if I can use either or if the connection is only for butane.
Any advice appreciated.
4,099
Please read the forum etiquette for new members regarding reopening old threads. Hopefully the Moderators will move this to a new thread.
But to answer your question.
The connection you have is specifically for screw on Butane cylinders. However the regulator is compatible with both Butane and Propane, and all you need to do is to get the Pigtail ( the flexible hose with the butane connector) changed to a Propane Pigtail.
The only other concern is the bulkhead mounted regulator should be fixed higher than the top of the gas cylinder, to prevent the possibility of heavy ends( the remnants of oils and other contaminants that are present in commercial grade LPG cylinders) from reaching the regulator.
Jun 13, 2025
10
Apologies, I did read the 3 month rule but was on auto pilot there! Used to a local car forum where we do that. Will keep that in mind.
Thanks for the advice, will maybe just play it safe and get a buntane and look again next season when we’re not so close to heading off
4,099
Butane is fine as long as the ambient temperature remains above about 5C. The reason is because the liquefied gas inside the cylinder draws heat from the atmosphere around the cylinder to have the energy to evaporate the liquid into its gaseous state, and the vapour pressure it creates in the cylinder is also temperature dependant. the lower the ambient temp the lower the cylinder pressure.
In addition as you use gas from an LPG cylinder (Butane and Propane) the cylinder needs to evaporate more liquid to replace the gas you have used. This further cools the liquid content of the cylinder, so even though Butane theoretically would stop gassing off at 0C the fact gas usage cools the liquid below ambient means that for practical purposes Butane can become temperamental at about 5C ambient.
Exactly the same thing happens to Propane but the big difference is it has to be cooled to about -40C before it stops gassing off. So Propane is the choice for winter caravanning, and in fact its safe for all year round use in the Europe and the UK.
The cost of buying a Propane pigtail is typically between £10 to £15, If you are competent you can change it your self, but its literally a 5min job .
Generally Propane is cheaper to buy compared to Butane, and whilst there is a slight difference in the heat that can be obtained from the same mass of either LPG, its small and you are not likely to notice it. Propane cylinder can often be found cheaper from builders merchants, than caravan/leisure retailers.
Reactions: BurningSmell
Jun 13, 2025
10
Thanks for the info. I called in to exchange my 4.5kg blue butane to be told they no longer offer these as they’ve removed them. Offered a yellow 5kg butane which they think would also need a different attachment 🤷🏻‍♂️
It’s going in for some revealing next week so going to ask the pigtail be changed to propane
Mar 3, 2022
381
301
4,935
Calor reissued 4.5kg butane a few months ago.
8,382
I learnt my lesson many years ago. We were on Dartmoor in late October and I couldn’t figure out why the gas heater wouldn’t light. Looking outside gave me the answer as everywhere had a beautiful coating of frost. Changed over to propane after that and never returned to butane.
4,099
IF you do have the pigtail changed, make sure you keep the old one, just in case you need it in the future. The only thing to remember is the hoses do have have to be changed due to age.
4,099
The OP already has some 6kg Propanes.
He can use these rather than the dumpy building site 3.9 ones. The gas compartment in most caravans are designed for 6 kg hence the retaining straps may not securely fasten the smaller ones
The 3.9kg propane is the same size as the 4.5 butane, which has been the traditional size of cylinder for UK caravans. The difference in the weight of gas is due to the specific gravity of propane being lower.
3,152
And I believe that the 3.9/4.5 kg "dumpy" has the same diameter cylinder and base as the 6/7 kg cylinders so fit most caravan gas lockers - they're just shorter.
4,843
I am sure that in the OP the poster state that they had a 6kg propane and not a 3.9kg propane so not sure why the 3.9kg is even being discussed? :unsure:
4,153
Because the thread has drifted slightly, as Normal.
So in theory, Burning smell, should be able to swop their 4.5 kg Butane for a 3.9 kg propane.
8,382
Thats right. the OP at post 1 does say he has a 6kg propane cylinder and previous owner used 4.5kg butane.If it were me I’d standardise on 6kg propane.
4,843
The previous owner had the 4.5kg Butane bottle, but not sure if the OP now has the previous owner's 4.5kg Butane bottle. I think in the OP the poster wanted information on the connection and not the bottles?
