- May 12, 2011
- 364
- 0
- 0
I know this has been raised many times in the past and even been an advice article in the magazine but it seems to have quiet for a while. Has the incidence of these failures decreased? I ask because last week I became a victim. We took our Swift Charisma 550 van which was only purchased brand new in April 2010 out of stoarge, had it's first service done, and went away two weeks later. As soon as we tried to light the burners it was obvious there was a problem with low pressure. I checked all the obvious connections, no problem, then smelt gas and could hear a leak. So I obviously disconnected the bottle and took it back to the dealers the following week but it meant a week of living off salads, take aways and microwaved food.
The dealer did a quick check, showed me the gas was leaking from a small yellow nipple on the side of the Trauma regulator and said it was not under warranty because it was caused by contamination in the gas. I should have done more right then but with a hospital appointment due very shortly I let them change the regulator for £40 and drove away seething.
Four things keep going through my mind:-
1) Why does a failure like a contaminant blockage lead to a highly dangerous gas leak? It strikes me as negligent in the extreme for this to be designed in. I've read in prevoius posts of people converting back to bottle top regulators being warned of illegalities and dangerous practices but it seems professional can do worse.
2) How does one check what the actual cause of failure was, Trauma, Swift or the dealer seem to be able to wash their hands of any responsibility now, just blame it on contamination before even removing from the van?
3) Why did the same bottle as used on my old van for a season not contaminate the old regulator?
4) Why wasn't the problem picked up at the service?
