gas regulator change over valve
644
We have just changed our caravan and our old one had a Truma duocomfort gas regulator that allowed the use of a butane and propane cylinder,and we could switch between the two simply by turning a dial on the regulator. Our new van has a single regulator that can only connect to one bottle .So if the gas runs out you have to change the bottle over by hand. Does any body know whether I can replace the new regulator with the old one, which was original fitment on the old van.Alternatively can I buy a new replacement duocomfort valve from Truma?
644
Hello Sproket
That looks similar,although I have never used it to automatically change over the supply from one cylinder to another,on ours you could turn the dial on the front enabling a choice of cylinder or when one ran out you just turned it to the other cylinder.
Thanks for your help
Aug 25, 2010
167
It looks very similar to the one on my 'van. I use it manually as I prefer to know when one bottle has run out. Mine works in conjunction with the original bulkhead regulator so I guess that so long as the reg you have is compatible with the change over you should be ok. Best to check exact model before buying though.
