gas ring wont stay on
Feb 27, 2010
14
having problems with my gas hob it will light on 1 ring only but only when i have the control push in when i let it go it just goes out. is this an easy fix or would i better just changing the hob.
3,845
1,563
It sounds like its probably simply that the "gas failure" systems thermostat has failed; a job that an honest service man should easily be able to replace. Its an item costing just a few quid, and is what I would try first. If its the valve itself it will cost a bit more but way way less than a new hob.
I cant advise you to do this simple job yourself on a public forum otherwise the self appointed H&S "police" will be on my back!
Feb 27, 2010
14
the controls feel very sticky. just bought this van and need it fix going away with it next week any avise is welcome.
creid.bad101@googlemail.com
