I have heard that Swift are recalling all Hankook tyres due to cracking problems. Does anyone know the details such as date or batch numbers?
Hi again - an updateHi guys,
Matador tyres are standard fit on Eriba caravans - usually a 195/70 SR 14 on a 1000 kg, 1200 kg or 1300 kg axle or a 185/70 SR 13 on the sub-1000 kg axle.
So, on the assumption that the Matador tyre problem is a batch manufacturing fault - and probably related to one tyre size - in 2006, I'd be interested to hear what tyre size you've had problems with.
And can then post a warning message on our Eriba Forum
Robert
hi paul so what does that mean you have to fix your own tyres as swift are not interested in helping youHi again - an update
I have now had response from Swift on Matador tyres:
"In some instances between the DOT range 40/05 through to 46/05 the tyre side may develop side-wall cracking".
I assume the figures refer to the date of manufacture of the tyre, which is shown on the sidewall of the tyre. For example 4005 shows a tyre manufactured in the 40th week of 2005.
However, my tyres, which have developed cracking are 4905, which is outside the date range stated in this response from Swift.
Paul
