HARTAL DOOR LOCK.
Jan 15, 2011
570
8
18,885
Hello all. I have a worsening problem with the door lock on our Bailey Ranger Van.
The Door lock has always been awkward to open from outside the caravan. The main problem is that the OUTSIDE Door handle doesn't withdraw the catch quite enough and the door tends to snag a little when opening.
The locking action works no problem and if we open the door using the key then the catch is withdrawn fully and the door opens with ease.
Likewise when opening the door from the Inside the catch fully withdraws and the door opens no problem..
I have read a few threads regarding these locks dating back a few years and they did have issues with the mechanism sticking but I wouldn't describe my issue as sticking.
It seems that the action of the outside door handle is out of adjustment or indeed is worn so much that it can not fully withdraw the catch although the caravan is a 2010 model I would hope that wear is not the problem.
Can anyone with a similar experience put me right re how to resolve the issue, I am itching to get the screwdrivers out and have a go at it but am aware that the caravan is still under warranty but don't fancy the 100 mile round trip to where I bought it from.
I have often regretted that my nearest Bailey dealer 9 miles away didn't have this model in when we were buying.
We probably got one of the last of the Traditionally made vans before Bailey changed over to the ALU TEC Style. The Ranger GT60 is a perfect weight match for our Tow Car hence we had to shop around a bit to find a dealer who still had one in stock.
Regards to all.
Brian
4,465
You say your caravan is still under warranty. I have to assume you are refering to the Manufacturers warranty, in which case any of the manufacturers participating dealers should be able to undertake manuafacturers warranty work. If in doubt check your warranty documentation or directly with the manufactures customer care department for clarification.
Jan 15, 2011
570
8
18,885
Thank you for that reply Prof John.
as I understand it the van and all it's bits fridge heater etc are covered for 3 years and the water Ingres is covered for 6 years provided of course I keep up with the servicing via approved dealers.
i know new cars can be taken to dealers of the same brand for warranty work but didn't expect it to apply with caravans. I will get all my paperwork out tomorrow and give my local Bailey dealer a call and explain the situation. When we collected the van the dealer pointed out that all warranty work must be returned to their workshop.
I think this door handle may only need a minor adjustment all be it internally and dont fancy a long haul just for that,
Thank you again for your reply.
regards Brian
5,551
Hi Brian
I'm on my third Hartal lock. The latest has now lasted two seasons with no problems.
Looking at my Bailey handbook you can use.any Bailey authorised dealer. However it is very important you first seek both Bailey and the supplying Dealers agreement on just who does the repair. Also you need to be sure your local dealer is willing to do your warranty work.
Your problem sounds different from the original Hartal faults which were sticky shafts.
Jan 15, 2011
570
8
18,885
Thank you for your reply Dusty Dog.
I did find some posts re these locks and mine is certainly not sticking. I presumed that the sticking problem would have been resolved in a 2010 van because the posts I read predates that and If it was a design fault I should have thought the supplier would have made the necessary modifications to the design before mine was made.
My problem is purely the the outside operating lever for need of a better description doesn't quite retract the locking tounge quite far enough. By watching the action with the door open the internal opener retracts it almost fully as does the key when used from the outside.
I am not able to get the van out this week but I will speak with the local dealer to see if he would be willing to look at it next week otherwise I look like having to make quite a round trip to take it to the supplying dealer.
Not really my week so far I wonder if you have seen my comments on the thread regarding Kampa air awnings. In the equipment and accessories section.
I have just spoken to the supplier re a problem with the one I bought last Monday and he has suggested that they will send it back to Kampa for repairs rather than just swap the thing. When I said that I wasn't happy with that he says he will ring Kampa then call me back with what they say.
Frustrating because the damage although minor was clearly inflicted at the factory either prior or during packing.
thank you again for your reply regards Brian
2,362
Hi brian, we have exactly the same problem with our Hartal lock. The catch doesn't seem to retract far enough when opened from the outside. Not a problem from the inside. Doesn't always give us trouble though. At the last service we mentioned this and I think they lubricated it and it wasn't a problem for a while, but has been playing up again lately. Our van is a 2011 eldiss. Let me know how you resolve it.
mel
Jan 15, 2011
570
8
18,885
Thank you for your reply Mel. After your post and before ringing around to see if a dealer will help I decided to follow your lead and lubricated the lock mechanism as well as I was able through the key slot, the latch slide and also holding the handle out exposed a couple of points I was able to get lubrication in as well.
I used a microfine lock lubricating Graphite powder from a specialist locksmiths shop.
I believe I have had the same result as you because the lock now opens more cleanly from outside.
When I watch the action with the door open the latch still does not retract as far with the outside opener as it does with the key or the inside handle, but it actually clears now so the lubrication has had a small but usefull effect.
I suspect that it may gradually return to what it was given time, but five minutes with the lubrication may get it away again.
from reading other posts these locks appear to give most people problems to some degree, I am at a loss why caravan manufacturers haven't dug their heels in with Hartal and bullied them into making some modifications surely a tweak here and there during the assembly process could resolve many of the problems. Perhaps the owners of Hartal and caravan manufacturers don't actually use caravans themselves so not experiencing the problems first hand.
best regards Brian
Nov 28, 2007
490
12
18,685
best regards Brian
Nov 28, 2007
490
12
18,685
I'm having difficulties replying to this. Final try disabling rich text?
My lock does the same and have yet to solve it. However it also had the other problem these locks have, a jammed lock, it being the internal handle that sticks in the inner part of the lock, this has to turn using the key from the outside. If you undo the 4 screws on the inside the lock separates front and back, nothing springs out, there is then a circlip to remove and the inner handle comes out. I then used emery cloth till it rotated easily. I was forced to do this on holiday this month.
I have some photos if I can find a way of attaching. I know this is not the answer to the original query, but it my help, particularly with the pictures.
Apr 9, 2006
1,011
We have exactly the same problem with the Hartal door lock on our 2008 Swift Challenger and will ask our dealer about it, when we take it in at the end of the month for the water ingress in the front wallboard to be sorted. Ho Hum.......it's one problem after another.
May 22, 2015
I have same problem with my lock and replaced it two times.I dont know what to do with it.Looked into many guides and threads but nothing was helpful.Every time it got stuck, have to bring locksmith to repair the lock they lubricate it, it works fine for some days and after that same problem.If anybody get any reliable answer please let me know.
Mod Note: External Link removed.
Aug 15, 2015
Post Removed.
Poster was someone who obviously has no knowledge of caravans but was simply trying to use the forum for personal advertising.
Hard luck, you have been rumbled and banned.
Nov 28, 2007
490
12
18,685
Photos. Note to remove the internal handle to lubricate or sand it down the spindle, you really need circlip pliers.
er. photos -How?
Sorry - failed.
Nov 28, 2007
490
12
18,685
er. photos -How?
Sorry - failed.
Ha, just read, I have to joint something called Photobucket. No thank you. No other forum I use needs this. Why should I save my photos to a remote server. What's in it for someone?
Parksy
11,904
2,400
ChrisUK said:
er. photos -How?
Sorry - failed.
The reason why the owner and administrator Haymarket don't host your pictures on this website and forum themselves is that Haymarket are amongst other things a well established publishing and digital media commercial company.
Unlike most of the other forums that you use Haymarket are bound by laws on copyright.
This forum is a free of charge public access forum which is paid for by Haymarket and as such there are no built in controls which would prevent any picture being copied and redistributed either to or from here by any individual or organisation.
If the website was administered by private individuals or even smaller commercial companies, as most caravan related websites are, this wouldn't matter but for a large and very well funded commercial company there is potential for legal complications and issues.
In other words, Haymarket's massive global profile makes them worth suing.
This is why pictures and photographs come to Haymarket via a third party, Photobucket.
Nov 28, 2007
490
12
18,685
Parksy said:
ChrisUK said:
er. photos -How?
Sorry - failed.
OK, understood.
chenzhen
BANNED
May 19, 2016
99
"The word vintage, used to describe dresses and clothing, is a broad term that is generally used to refer to clothing that originates from a past era. In general, clothing that dates earlier than the 1920s, is considered to be antique. Whereas clothing and dresses that have emerged after the 1920s, up to the 1980s and 90s, is considered to be vintage. Retro, or vintage style, usually refers to clothing that is an imitation of the style of a previous era.
A range of vintage style clothing that is hugely popular today, are the fifties dresses. The enduring popularity of these dresses, might be because that was the time women's clothing made significant strides, as it was after the second World War and many restrictions had been lifted and designers had more freedom and materials available to create beautiful women's fashion ranges.
Some of the popular dress styles that have enjoyed a timeless appeal have included the Ophelia dress, floral tea dresses, Audrey Hepburn style dresses, the figure hugging Lindy Bop dresses and dresses made famous by Grace Kelly and many classic Hollywood stars. Even today, young women are choosing vintage style dresses for their special occasions such as a ball, prom night, and other formal parties, because they have a definite charm and elegance and have been designed to enhance a woman's shape and beauty."
fake oakleys
michael kors uk
cheap ray bans
rolex watches for sale
nike free flyknit 5.0
ugg boots
coach outlet online
yeezy boost 350 white
michael kors bags
air max 90 white
ralph lauren outlet
louis vuitton bags
converse sale
coach factory outlet
adidas shoes
nike free flyknit 3.0
burberry outlet
nike air force
cheap ray-ban sunglasses outlet
tory burch shoes
nike tn pas cher
chaussure louboutin
adidas nmd runner
louis vuitton handbags
skechers outlet
oakley sunglasses cheap
cheap jordan shoes
ray bans
adidas nmd black
reebok classic
adidas trainers
vans store
nike cortez white
pandora charms
air max 90
adidas shoes
fitflops shoes
timberland uk
pandora charms uk
armani exchange
burberry bags
under armour
louis vuitton outlet stores
oakley sunglasses wholesale
pandora jewelry outlet
cheap basketball shoes
ferragamo
ralph lauren
pandora rings
toms outlet
michael kors outlet online
prada sunglasses wholesale
cheap ray bans
www.coachfactory.com
cheap air jordans
michael kors handbags
valentino
michael kors outlet clearance
michael kors outlet
ugg boots
ralph lauren
ghd
mizuno running shoes
nike air force black
cheap jordans
nike free run flyknit
cheap ray bans
sac longchamp
kate spade outlet
cheap ray ban outlet
ray bans
true religion jeans
babyliss hair dryer
michael kors bags
true religion outlet
reebok outlet store
ray bans
nike trainers
polo outlet
fitflops
adidas superstars
true religion outlet store
kate spade uk
discount nike air max
ray ban sunglasses outlet
jordan pas cher
levis 511
nike huarache
omega speedmaster
christian louboutin uk
michael kors outlet store
tiffany jewelry outlet
polo ralph lauren men
adidas supercolor pink
rolex replica watches
ray ban outlet store online
cheap nike air max
coach outlet store online clearances
tory burch flats
hollister hoodies
nike cortez shoes
louis vuitton outlet online
hollister hoodies
pandora jewelry
louboutin outlet
coach factory outlet online
adidas pure boost black
designer handbags wholesale
yeezy boost 750
true religion
kate spade outlet online
tiffany uk
lebron james shoes 12
red bottoms outlet online
cheap jordan shoes
jordans
gucci borse
gucci handbags outlet
ray ban sunglasses sale
lacoste shoes
bottega veneta shoes
michale kors uk
ray ban sunglasses discount
louis vuitton uk
cheap ray ban sunglasses
longchamp outlet
micahel kors
adidas superstar white
air max
cheap nfl jerseys
burberry outlet
christian louboutin outlet
hollister clothing store
oakley sunglasses outlet
ralph lauren
nike blazer
michael kors canada
birkenstock sale
cheap ray bans
white converse
louboutin pas cher
jimmy choo
ed hardy uk
bottega veneta sale
north face outlet
nike air max 95
burberry sale
abercrombie and fitch outlet
hollister kids
louis vuitton purse
supra outlet
nike huarache black
nmd adidas
asics running shoes
lacoste polo shirts
jordan shoes
michael kors canada
abercrombie & fitch
coach outlet online
tiffany jewelry
burberry outlet canada
ray ban sunglass,ray ban sunglasses,ray ban outlet,cheap ray bans,cheap ray ban sunglasses,cheap ray bans,ray bans
ralph lauren outlet online
canada goose outlet
mlb jerseys wholesale
vans outlet store
birkenstock sale
coach purses on sale
ferragamo outlet
valentino bags
rolex submariner
mont blanc outlet
hollister co
nike air force
the north face outlet
armani outlet
tiffany and co outlet
michael kors handbgas
cheap oakleys
north face jackets
dior sunglasses 2016
coach outlet online
north face uk
kate spade bags
polo ralph lauren outlet
ray ban outlet online
adidas nmd uk
ghd hair dryer
jordan shoes
hollister uk
michael kors uk
buy red bottoms
nike roshe run
kate spade outlet
toms shoes
cheap oakleys
louis vuitton factory outlet
polo ralph lauren outlet online
puma outlet
true religion uk
chi flat iron
fitflops sale clearance
true religion jeans outlet
michael kors outlet canada
michael kors outlet
oakley sunglasses
instyler max
true religion jeans
fitflops
fitflops shoes
polo ralph lauren
pandora sale
michael kors outlet stores
hermes outlet
cheap oakley sunglasses
nhl jerseys wholesale
toms outlet
longchamp uk
timberland shoes
asics gel kayano
michael kors outlet
ed hardy
polo ralph lauren
versace sunglasses wholesale
louis vuitton borse
kate spade handbags
new balance shoes
versace sunglasses
birkenstock outlet
oakley sunglasses,oakley sunglass,cheap oakley sunglasses,oakley sunglasses cheap,oakley sunglasses outlet,oakley store,oakley outlet,oakley outlet store,oakley sunglasses sale,oakley sunglasses discount
michael kors bags
birkenstocks
nike air max 90
timberland boots for men
kobe bryant shoes
adidas shoes
birkenstock shoes
christian louboutin shoes
under armour outlet store
rolex daytona
michael kors outlet
abercrombie outlet
birkenstock uk
cartier
omega
polo ralph lauren
true religion sale
burberry outlet stores
nike shoes for cheap
nike store uk
sac longchamp pliage
nike force 1
ecco outlet
coach outlet online
louboutin shoes
canada goose jackets
nike free runs
reebok
converse outlet
coach outlet online
stephen curry basketball shoes
hollister kids
jimmy choo outlet store
nike air max 90
hermes belt
louboutin shoes
supra store
stan smith adidas
toms outlet
rolex watches uk
wholesale nike shoes
gucci outlet online
yeezy boost 350
nike free 5.0
cheap nfl jerseys
reebok shoes
coach outlet online
coach outlet store
tiffany and co jewelry
timberland shoes
ray ban outlet
timberland boots on sale
cartier love ring
white converse
louis vuitton purse
air max 90
ralph lauren pas cher
air jordan shoes
prada handbags
michael kors canada
holliste sale
adidas gazelle
nike flyknit racer
oakley sunglasses uk
yeezy boost 350 balck
lebron james shoes 2016
ralph lauren outlet
nike running shoes
kobe 11
nba jerseys wholesale
coach outlet store
michael kors handbags outlet
hollister clothing
louis vuitton pas cher
ralph lauren sale clearance
cheap oakley sunglasses outlet
"One of the most popular, but simple fifties dresses, is the petticoat. This was designed to be flattering to a lady's shape and also, to enhance the dress she was wearing over it. Petticoats made of silk and woollen materials were initially introduced for women to wear under the main dress, as they provided warmth and would enhance women's busts. The classic petticoat then became shorter and lacy petticoats became the fashion, as they delicately accentuated the dresses that were worn over them, such as the Ophelia dress.
Vintage style dresses UK are available in a wide variety of sizes from vintage clothing shops, textile fairs, auctions, flea markets, estate sales, antique markets, garage sales and collectable fairs. However, there is always the risk with buying genuine vintage clothing, that the sizes may not match current clothing sizes. But there are a number of special boutiques online, who specialise in designing and creating vintage clothing to order. They can take your specific measurements and produce an outfit that will be tailor made and fit you perfectly"
RSDLGKMLGMGM
