Has anyone fitted a TV bracket inside a Bailey D4-2 caravan?
Aug 24, 2025
Good morning all, I'd like to fit a TV bracket to my Bailey D4-2, and the only logical place is above the fridge where the plug and aerial socket is. However, the bracket would have to go on the wall of the van. After researching, I've discovered this might not be possible and the bracket should really go on an internal wall such as a cupboard, however there is nothing suitable that's close enough to the aerial and plug socket. Has anyone figured out a way to get round this?
Nov 30, 2022
2,021
1,930
5,935
You will probably have to stand it on the worktop rather than fix it to the wall (which as you say isn't strong enough)
It might be worth contacting Bailey to ask if there is a strengthening plate built into the wall designed to take a TV bracket as thats what is done to facilitate cupboards being wall mounted.
Reactions: Jcloughie
Aug 24, 2025
Thank you so much for your reply Mr Plodd☺️, that's really helpful. I will contact Bailey and see what they say.
