Fresh water. You can add some home brew cleansers to warm water and cleanse every surface your beer comes into contact with. Non rinse means that unlike some cleansers, you don't have to run clean, cold water through after the steriliser, which saves timeAre you talking fresh or grey water, and what do you mean by 'non-rinse'
I’ve never used Puriclens for longer than an hour or two in my caravan systems and then flushed them out with fresh water. Not had any stomach issues from caravan water supplies and in most cases we used the supply from the Aquaroll for drinking too. Don’t the instructions say 1 to 12 hours?I take your point Jezzer B. Many fermenters are manufactured from food grade stainless steel, I would assume caravan tanks are the same. Having looked at the instructions for the steriliser mentioned in this thread. Its supposed to be held in tanks and pipes for 12 hours.
Whilst I 'm not advocating doing a Donald Trump ( drinking bleach to stop covid!!!), homebrewers use diluted, non rinse steriliser to sterlise beer bottles, fermenters etc. - which do not kill the yeast, and certainly do not need 12 hours to work, hence a time reduction on sterilising pipes. Has anyone looked at it or taken advice on it, been advised for or against? Just askin
PS I only tended to sterilise at the start of the season and then before any prolonged storage.
It issupposed to be the Miltons that stains stainless steel?For years, I've popped a couple of Sainsbury Baby Bottle sterilizing tablets in the half-full Aquaroll, then pumped it through to the taps. After leaving it for a short while, I've drained the system and refilled with fresh water. And does it harm the stainless steel? The last time I fitted a new heating element, the tank was shiny and bright inside.
I think both the tablets for baby bottle sterilisation and Milton work in the same way by releasing chlorine as the sterilisation chemical. Stainless can be attacked by the chlorine that’s why advice tends to be not to use it.It issupposed to be the Miltons that stains stainless steel?
Although I seem to recall that on earlier caravans sterilising fluids like Milton were ok’d in the Owners Manual. Or is my memory fading? When Puricleans came along I changed to using it.Is it not way best to use the "right" product, one approved by the makers of the kit involved, here the likes of Truma, Whale, or Alde as possible examples, than try to outsmart them using something else?
Or is it just me, that feels the makers know best re caring for the kit they manufacture?
There are undoubtedly dangers in initiating pitting and crevis corrosion on stainless steels with the use of products and procedures not approved.
I would think that none of the makers of the kit involved manufacture the cleaning chemical items. They simply buy in the comlete chemical as a powder or fluid and re-package it. The identical chemicals used for Puriclean could be used in several other products under different names.Is it not way best to use the "right" product, one approved by the makers of the kit involved, here the likes of Truma, Whale, or Alde as possible examples, than try to outsmart them using something else?
I was not aware that you were a manufacturer of cleaning products?No of course "we" did not buy in the chemicals, nor did we make the care products we approved.
We did though test what we approved, and also we neither tested nor approved those where it was evident, they contained "stuff" or had application procedures we knew, even without testing, could result in damaging our kit.
Interesting link and good for newbies to read plus a refresher for us oldies. Many years ago we were on a seasonal pitch. We went in the morning to top up the water barrel and someone had empty the contents of the cassette at the tap.The 2010 Caravan Club advise sheet on water systems makes interesting reading particularly the piece provided by Kings Lynn Environmental Health Department. Bit OTT or what.
https://www.caravanclub.co.uk/media/1022808/water-matters-mo.pdf
That link is 2010. The latest CMHC page is far more generalised. Times move on I guess.Interesting link and good for newbies to read plus a refresher for us oldies. Many years ago we were on a seasonal pitch. We went in the morning to top up the water barrel and someone had empty the contents of the cassette at the tap.
This tap had no drain under it. Very unpleasant. Luckily we had disinfectant in the caravan and gave the tap a thorough clean.
We suspect that it was some newbies that had arrived the day before and left very early in the morning as they were the only caravan that had left early.
https://tubingchina.com/Selection-of-Stainless-Steel-for-Handling-Chlorine-Cl2-and-Chlorine-Dioxide-ClO2.htm#:~:text=Chlorine is a powerful oxidising agent. It normally,in water it can be a corrosion hazard.That can't be right! Take a look at the Product Safety Data for Puriclens Tablets. One of the listed ingredients is "Chlorine-based bleaching agents."
