Going over to france but wont be using car in the dark , do i still have to put deflectors on and if so can you use home made ones such as black tape etc. going again in summer , have bought some for then but didnt want to waste them on short trip
Moulded plastic beam benders are not precision optical devices and therefore cause more scatter than they prevent.You should not use blanking masks on modern plastic headlamps, as the heat build up causes minute fractures in the plastic, which can cause more light defraction and could well fail the lighting test when being MOT'd
Use the clear plastic beam bender, as thes do not cause any heat build up.
Steve W
That would get you nicked, the law is dipped beam headlights in adverse weather conditions.As an alternative to using headlights in poor visibilty conditions during the day, you could use your side lights and front fog lights.
