- Jun 16, 2020
- 5,792
- 2,710
- 17,935
I am considering installing one of these. Looking to see if anyone has any experience.
First looked at the whole house with a unit fitted in the loft and ducted from there. The ducting would not work. So then considered a cut down version, but that still needed two 100 mm ducts through the main bedroom. Possible, but not desirable. Now looking at a single room one. Cheaper, and we only have the problem in the living room. Problem there is we don’t have a suitable outside wall to fit it, so would have to go through to the garage.
Why? You may ask.
We did not know we had a problem until I added an accessory to my heating system. It provides accurate internal and external temp eater forecasts and air quality in various ways. This is what it reads right now. The house is empty and there is a window cracked.
The advice is that normal outside CO2 should be 400 but to keep inside to less than 1000. In the evening it shoots up to 2000 and when we had friends around 2500.
Filters will not get it down. Submarine scrubbers would, but not practical. Opening a window can work. But not ideal in the cold weather. So one of these units seems to be the answer. Ventilation without draughts and little loss of heat.
Does anyone have any experience of them.
PS, I am aware that such a unit would brake the fire regs between house and garage. But not that bothered as we don‘t use the garage for a car.
Why? You may ask.
