Hello from Bristol
Jun 16, 2010
Hi we have recently purchased a secondhand caravan a Adria Optima 400 main uses will be for weekends away at the track as my son does motorcycle racing, just a few questions in the toilet/shower the shower head has red banding on it does this mean it is suppose to have hot water to it, as reading on the net i can not find out wether it should have hot water or not.Any any advice on such caravan would be much appreciated.
Apr 15, 2010
96
normally a shower would have hot water,do you have hot water to the other sinks?if not is there a boiler fitted under a front bed locker.your problem could be anything realy,check water pipes,is there two pipes to the shower does one go back to the boiler,is there water but not hot,go over the system as we need more detail of the problem and post in technical.sarah
2,400
Hi Karl
Welcome to the forum, I'm sure that someone will answer your questions about the Adria in the technical or Equipment & Accessories section.
Most caravan hot water systems use either 240v or LPG if you are not on an electric hook up. You will need an Aquaroll to fill the caravan water system including the boiler.
Jun 22, 2010
23
I own an Adria Optima 350B. The shower head on mine also has a red band, but the caravan does not have a hot water system.
