Hello .Can any one offer any advice re fixing my rear lamp cluster.
Have recently had a indicator bulb fail (first one ever since purchasing caravan new in 07/2003) Removed lamp unit etc replaced bulb reinstalled unit only to find that the 5mm x 40mm self tapping screws that pass through the lamp unit and locate and screw into the ABS rear panel don't hold securely. Cannot use a bigger diameter screw as this will not pass through lamp unit.
Has been suggested by manufacturer that I try and glue a piece of wood on to the inside of ABS panel and drill a pilot hole into this .
I don't know if I can get to this point on the inside I'm not sure they do either !!
All contributions gratefully received thank you as the duct tape securing it at the moment looks very unsightly.
Ta Peter
Ta Peter
