Help in Fixing Draught Skirt Wheel Arch Cover
Jan 7, 2007
171
17
18,585
We bought a brand new 'van last year and have failed in trying to fix the wheel arch cover to the caravan bodywork using velcro. I dont want to drill holes in the panels for the poppers/studs as this will invalidate the warranty. Any suggestions or does anyone know where I can get industrial strength, outdoor velcro in white? Cheers Brian
Dec 9, 2007
383
The wheel arch skirt usually comes with custom holes for said suction pads which, btw, work fine.
Dave
May 5, 2005
1,154
we used velcro and when we pulled the bits off when they went black wth dirt the residue was really tough.took most of an afternoon to get the marks off.weve now got suckers from kleeneze and put eyelets in the awning bit works fine
Nov 4, 2004
1,191
I stuck my poppers on with the Isabella fixing kit,10 popper backs solvent cleaner araldite real easy to do.
May 18, 2006
593
16
18,885
I had to drill a small hole through the centre of each eyelet and then used suction pads from Wilkinsons - which cost about 50p for 3.
5,318
Hi Brian
What make of 'van did you buy?
Most of the new Bailey's have a hidden groove, like an awning rail, within the trim over the wheel arch. Just a thought otherwise the advice given to you so far is excellent.
Alan
Jan 7, 2007
171
17
18,585
Hi everyone, many thanks for your useful suggestions. The caravan is an Abbey Expression 550 (a Vogue 540 special edition jobby). Thinking about it (the caravan is back in storage now after a week in Cornwall, so can't check right now), I think there are some kind of eyelits in the plastic wheel arch - any idea if they are removable/used for securing the cover? cheers Brian
Jan 23, 2008
20
Suction Cup CLAMP 47mm Window/Sucker/Cups/Suckers Item number: 170224068944.
I use the above suction cups no need to mark caravan or put holes in awning skirt.
May 22, 2006
266
Been using suction suckers with a wire type hook but just bought a card of 16 from Tesco with 4 large, 4 medium and 8 smaller suckers with plastic hooks to use this year
Cut out a piece of plywood or hardboard and slide this in between the wheel and the wheel arch. Neat and tidy and does a better job.
Jul 11, 2006
305
I Use a 1" thick piece of foam rubber cut to the appropriate size and covered it in plastic this can then be pushed in-between the wheel and arch and seals the gap well.
Jun 9, 2008
22
Best tip I ever got, was to use Blue Tack thro' the eyelets. Works a treat, and no marks!
Pop
Jan 7, 2007
171
17
18,585
thanks for all your comments. I bought some rubber suction pads off ebay and they worked a treat. All traces of velcro now gone and it looks really tidy! thanks again, Brian
