Help please -can someone write a quick get started list?
Hi
Please can anyone help, could someone jot down some do's and don't for someone who knows nothing about caravans and might be interested in getting one?
eg: the new law in which you have to have your licence for so long before you can tow
Weights, 85% guideline
Pros and cons of bying from dealer/private
Plus anything else you consider relevant at this stage.
Many thanks in anticipation.
Lisa xxxxxxxxxxxxx
If its of any help there is info on rules and regs on "new" driving licence and towing in this month's Caravan Club magazine.
Robert
Thanks.
I was hoping that if anyone had a little time on their hands this afternoon, they could precis something on here for me? Like an idiots guide for the beginner.
Many thanks. (cheeky I know).
Lisa
Hi Plotter
It's not for me its for an acquaintance. I was wondering if someone could do a quick guide as above (particularly an accurate bit about how important your tow vehicle is in relation to the laden weight of your caravan etc).
I needed it for later this afternoon and I haven't got time to type it up as I have a bit of problem on at the mo.
No worries, if no one can help, I'll type something up tonight.
Lisa
Looks like the delegation/management skills I have learnt whilst doing my current job arn't working!!! LOL
Lisa
Maximum sizes for towing
Towing vehicle under 3500kg GVW
Length (excluding the coupling and drawbar)
7.0 metres
Maximum width
2.3 metres
Towing vehicle over 3500kg GVW
12 metres if at least 4 wheels
Maximum width
2.55 metres
Length of towing vehicle & trailer combined
18 metres
Maximum overhang of load from rear of trailer
3.05 metres
Further information from: National Trailer and Towing Association (NTTA)
www.ntta.co.uk/law/
Maximum trailer sizes
Type 01: unbraked trailers - max. 750kg gross trailer weight or half the towing vehicle's kerb weight - whichever is less.
Type 02: trailers on overrun brakes - max. 3500kg gross trailer weight.
1982 regulations require that all trailers, including unbraked ones, must be clearly marked with their maximum gross weight in kg. This may be checked at any time by the police at a weighbridge. Since 1 January 1997, all unbraked trailer plates must show the year of manufacture.
Safe weight ratios
For stable and safe towing we would always recommend that you choose the smallest and lightest possible caravan suitable for your intended use. The less the laden weight of the caravan is in relation to the weight of the towing vehicle, the safer and more stable the outfit will be. The Caravan Club, for example, advises that you should aim for a towed load that is no more than 85% of the car's kerb weight for stability and safety. The CC advice is NEVER to tow above 100% of the car's kerbside weight.
N.B. The car manufacturer's specified maximum permissible towload is always the absolute towing limit regardless of any 85% or 100% weight ratio guideline. This is especially important in those cases where the manufacturer's figure is particularly low - in a few cases even below 85%.
Load distribution
Proper load distribution, in general, must be ensured too, with all heavy items in the caravan low down and directly over the axle wherever possible. Correct tyre pressures for car and caravan are absolutely vital.
Noseweight
It is a legal requirement that the noseweight should be 4% of the weight of the trailer or at least 25kg, whichever is the higher.. For safety you should aim for, but not exceed, the lower of the 2 figures specified for caravan and car respectively.
Passengers
It is illegal to carry passengers inside a caravan whilst on the road. It is permitted for pets to travel in the caravan, although this is not recommended safe practice.
Driving Licences
A full (not provisional) driving licence is required to tow a caravan. From 1 January 1997, new category B (generally held as 'normal' car entitlement) vehicles may be coupled with a trailer up to 750kg Maximum Authorised Mass allowing a combined weight of up to 4.25 tonnes MAM OR a trailer (for example a tourer) over 750kg MAM provided the MAM of the trailer does not exceed the unladen weight of the towing vehicle, and the combination does not exceed 3.5 tonnes MAM. This would mean that many drivers who possess only a category B on their licence would be able to tow a caravan provided it was not heavier than their car, and that car and caravan combined, does not weigh more than 3.5 tonnes.
New drivers of outfits over these limits must take a category B + E test.
Further information from: Driver and Vehicle Licencing Agency (DVLA)
www.dvla.gov.uk
Speed
Towed outfits may travel at up to 50 mph on single carriageway roads and up to 60 mph on dual carriageways and motorways. Towed outfits are not permitted in the outside lane of a three or more lane motorway unless other lanes are closed.
Brakes
A caravan with a maximum design laden weight of more than 750kg must be braked with an intertia (overrun) type braking system up to a maximum permissible laden weight of 3500kg.
Road lights
Caravans must have flashing indicators fitted at the back. A buzzer or other means of alerting the driver must be installed to highlight the failure of any of these indicators.
Caravans must have two rear lights conforming to certain size requirements and bearing the appropriate CE mark. Marker lights must be fitted 'as high as practicable' on the side or at the front and rear of caravans over 2.1m wide.
Carrying gas cylinders
Regulations relating to the use of liquid petroleum gas (LPG) in vehicles on the public highway require the gas to be shut off at the cylinder when no appliance is in use. While the vehicle is in motion, no gas appliance should be in use. Special restrictions apply in certain road tunnels, the Channel Tunnel and on ferries. DO check before setting off.
Parking
Do not park your caravan:
where it may cause an obstruction
at night on a road without lights
in street parking bays as some local laws forbid this
at a parking meter, as caravans are not permitted
unless securely braked or chocked to prevent movement
And finally ....
A caravan stored in its owner's garden may be used as a spare bedroom to accommodate non-paying guests. Friends can bring their own caravan and stay within the garden of a house.
Caravans must have a rear number plate, matching that of the towing vehicle, and illuminated at night.
TVs used in caravans are covered by the owner's domestic TV licence as long the caravan is occupied by someone resident where the TV licence is registered.
Caravans do not have to undergo an MOT test.
All safety regulations for car tyres apply to caravans. Retread tyres should not be used. Radial and cross-ply tyres must not be mixed on the same axle.
7.0 metres
Maximum width
2.3 metres
Maximum width
2.55 metres
18 metres
3.05 metres
www.ntta.co.uk/law/
Safe weight ratios
Load distribution
Noseweight
Passengers
Driving Licences
www.dvla.gov.uk
Speed
Brakes
Road lights
Parking
And finally ....
the above is from this very site
Get your friends to the dealer first, Lisa. They can advise on weights when the sell a van. Get them to drag you along too. The best way, is to have someone who knows about caravans, with them.
Whatever they do, don't let them rush into things.
7.0 metres
Maximum width
2.3 metres
Maximum width
2.55 metres
18 metres
3.05 metres
www.ntta.co.uk/law/
Safe weight ratios
Load distribution
Noseweight
Passengers
Driving Licences
www.dvla.gov.uk
Speed
Brakes
Road lights
Parking
And finally ....
Thanks Steve, really appreciate that.
Lisa
