- Nov 12, 2009
- 11,904
- 2,400
- 40,935
Hi
As preparation for the new season I thought I would sterilise the caravan water system on our Bailey Senator Arizona(S5/2006) by running a solution of puriclean into the water system. The 'van water system is based around a Whale Sureflo (UP0814) pump with 2 valves to give the options of
(1) Aquaroll to 'van taps
(2) Aquaroll to fill inboard tank
(3) Inboard tank to 'van taps
I removed the filter from the filler pipe that goes into the aquaroll to save contaminating it with the sterilising solution and began to fill the inboard tank with the puriclean solution in the aquaroll. At first all was well and the inboard tank was filling up.
Then however I began to experience problems. Although the pump is running it will no longer pump water from the aquaroll to the inboard tank or direct to the 'van taps. The pump WILL pump the water from the inboard tank to the 'van taps.
I wonder if some grit or other foreign body has got into the pump?
Does this type of pump have a grit filter that I could clean? Where is it?
ANY ADVICE would be very welcome we are due to go away for 11 nights commencing this Saturday but this will not be possible if we can't pump water into the 'van and I don't know if I can get anyone out to look at the 'van before Friday.
Tim.
Tim.
