HELP : Sterilising
Could someone please advise me of the above, we bought our caravan last october and we have not used it since just before christmas. were going away next weekend and i want to clean out the aqua rolls and the water system but not sure what to use and how much to use.
My caravan is a 2008 Sprite Alpine 2.
Wayne
Milton steriliser which is used for babies bottles is ok to use providing that you don't exceed the dosage of steriliser in the water (the amount will be in the instructions supplied by Milton) and don't leave the sterilising fluid in your water system for over two hours.
Flush the system and aquaroll out with clean water afterwards.
]http://www.practicalcaravan.com/newforums/fm_messages.asp?FO=1&FM=442178
http://www.practicalcaravan.com/newforums/fm_messages.asp?FO=1&FM=442178[/quote
thanks parksy, thats much apreciated.
wayne
For the attention of Parksy
Hi Parksy I have just had a look on my bottle of Miltons and I cant find anywhere where it tells me how much to put in Aqua roll.
Please help
Sir Roger
Pretty sure it's 20mml per 5 litres or one capful per 5 Litres.
l put eight capfuls for one Aquarol ran it through the system, left it for twenty minutes, then flushe out with 40litres of fresh water.
NigelH
As Parksy mentions, Milton will do the trick. However, if you have any doubt then many of us carry a separate water bottle of 5 litre size and fill that direct from the mains and use it for tea etc. Avoids any issues with the water system and you use that for washing etc.
Some people fit an inline filter system under the sink which appears to do a good job, or carry a free standing jug filter.
However, in the real world it is unlikely you will have many problems as the Aquaroll is filled and emptied fairly rapidly so the water does not lie in there too long. You also boil the water for tea. For children drinking, use a separate bottle as mentioned above, but do not buy bottled water from shops, unless you are very rich.
Thanks everyone for your advice.
wayne
Hi use citric acid,instead of Milton.use a tablespoon to half a aqua roll, leave in the system for 1/2 hr then flush with clear water. Purchase citric acid from local home brew outlet or the chemist.This will not cause a possable problem with the hot water tank as its pos with Milton.
Dave.
15ml per 2.5litres of water. If you have an inline filter either clean the system then change if or take it out and bridge the gap with a bridging length of pipe and connectors.
