Gav,
you advise Ian to use red diesel,don't let Customs and excise catch you using that ,its only for agriculture,farms and I believe canal boats.You'll get done if you use it.
Hi Ian
We have caravanned for 30 yrs without mains power, using an extension lead from the car battery. The places we stay are isolated and nobody wants a generator rumbling away all evening. We never had a problem until this year when I forgot to disconnect the lead before I drove off ...
We run fridge, water heater and cook with propane (red cylinder). It burns cleaner than butane (blue cylinder), and does not freeze up in winter. One 13kg propane lasts exactly 21 days and provides two hot showers each morning, half an hour's house heating on cold mornings, fridge non-stop, and all cooking/washing up.
We don't have TV or PC which does require considerable power, a generator is only way. PC can be used with an inverter in the car, but at 150W you must keep the engine running.
We do have good radio/cd player with four speakers in van, charge mobile overnight using car charger.
Lighting was biggest consumer. Original eqpt was four 11w 12v fluorescents, same load as one car headlamp bulb, will flatten car battery in about two hours. Instead we fitted 12v halogen spots for reading, this cut consumption by half. Couple of years ago we fitted 12v LED downlighters, all six will now run for over a week night and day before battery is affected.
We found www.ultraleds.co.uk very helpful with a wide selection.
I think the LED is the biggest advance in caravan lighting since we got rid of the gas mantle!
Today's oversize, overweight caravans are a long way from what we began with; many people ask about our car connection and are surprised that we don't even have a mains hookup cable. Life is possible without TV, Ian, you might even find its absence is part of your holiday!
