help with trip to france
Sep 6, 2006
22
hi we want to go to france with our caravan. we have not towed abroad before can anyone give us some tips ie good sites, best ferry, towing restrictions etc we have only had our van for a few months and allthough we have been to several sites in england we would like to go further afield but are very nervous we are thinking of going early sept for about 3 or 4 wks thanks franklin
May 11, 2008
58
Hi Franklin
Go for it! We're just about to have our second 'whole of June' in France, and went to Germany the previous June. You might feel you don't want to go too far, but we didn't have any problems that year, which was our first time towing abroad. Recommend Camping Cheques (www.campingcheques.co.uk/en/) for low season camping. They have loads of sites in France and the cheques work out very much cheaper at
Jan 7, 2008
56
hi,
we toured france for a month last year with the little ones,going back this year to different areas,its no big deal,roads ar good,sites are generally better than here with more facilities1
one piece of advice,many of the garages in france like here are supermarket run garages only they appear to be built only for 2cv's,we found many that only had one misleading way in and were impossible to drive through with a caravan and amongst blank expressions and non non non you willhave to reverse out which with the raised kerbs is entertaining,just something to bear in mind as we got caught in remote areas a few times having come past motorway stations and having to use these garages,
regards
andy
Sep 6, 2006
22
hi,
regards
andy
hi thanks very much for your comments it looks like we will just have to bite the bullit will let ypu know how we get on franklin
Jul 11, 2006
490
Caravanning in Europe is very enjoyable - as someone else said, go for it.
Also as stated, fuel in France is always cheapest at the huge supermarkets (which are great fun in their own right!) such as Carrefour, Auchan, and (the cheapest at the moment) L'Eclerc. Most of them have two 'sides', one for credit card payment at the pump (French banks only) or the other side for all other payments including UK cards (debit and credit.) If your 'van is long you may have to choose with care, but anything up to a 'normal' 14 footer or so, you will get through - with care. However when leaving the pump don't turn before your van is out of the 'slot' or you will likely take a chunk or two out of the sidewall of your offside 'van tyre as the islands usually have a stainless steel trim that sticks out a bit further than the masonry.
Most French motorways (autoroutes) are very smooth and often fairly empty, but it will cost you around 12c/Km when towing so costs can rise rapidly. Look at www.autoroutes.fr before your go and it will work out a route for a caravan without going on chargeable motorways (there are a few free ones.) If the sign is blue and says 'peage' it is chargeable - if you go the wrong way there is always an escape route before the entry gates.
As for sites, all cities and large towns, and many smaller towns have a municipal site which can be guaranteed to be clean, quite well appointed (i.e. mains at every pitch) and inexpensive. Beware though that your standard 25m UK mains cable may well be too short - carry two to put in series, plus a BS5750 socket/Schuko adapter as few continental sites (particularly France) have blue outlets. Also make a blue plug/socket tail with the L and N reversed as (in my experience) the vast majority are reverse wired. Supply current varies from 16A, through 10A down to 6A and even 3A, so choose your appliances with care.
As for places: France but not far try Le Touquet with its fantastic beaches or the end of the penninsula around Caen. If you want to go further Paris is always a good place, and there are good municipals at Angers, Samur, Tours, Bourges, Troyes and Rhiems. Alsasce-Lorraine is worth a visit albeit a long way - 1500 castles alone - and a good base is the superb municipal at Obernai. You can also cross the Rhine into Germany.
Belgium and Luxembourg should not be overlooked although they don't have the hypermarkets of the French: the municipal at Ghent (Blaarmeersen)about 90 miles from Dunkerque is very pleasant and Ghent has more to offer than Brugges (and some say Brussels,) the Ardennes in SE Belgium is very green with much forestation, and Luxembourg is worth a visit - especially as it has the cheapest fuel in western Europe by a margin!
Even though Holland probably has more caravanners than most of Europe, their sites are generally not set up to take tourers and few speak English although much of the population does. Germany sites are always well equipped but are few and far between.
Hope that helps - a bit?
Jul 11, 2006
490
I should also have said, get yourself a Nationwide Visa card as they do not charge for use in Europe (you don't need to have a bank account with them,) you only pay the exchange rate. If your ATM card is either Cirrus or Maestro you can use it at any ATM in Europe and it will talk to you in your own language. However due to the fixed usage charge on top of the exchange rate, use it to withdraw large lumps of cash at a time. Some machines will let you have _400, all should let you have _300 in a day. Despite what others may say cash from an ATM is the cheapest way to get hold of it overall.
Also beware that many fuel stations in France, Belgium and Luxembourg are now unmanned, especially outside normal shopping hours, and will only take credit cards on French/Belgian/Lux banks. You can have difficulty getting fuel in the evening or on Sundays particularly in the latter two. Supermarkets and large shops are closed on Sundays and public holidays, although smaller supermarkets and all bakers are open Sunday mornings - fresh bread is part of the French way of life!
40
Lots of good advice already. I suggest you joi8n Caravan Club abd get their Europe ! touring book for the best sites - reports written by members. Also lots og good practical basic advice which should take away lots of hassle. Like many others i'vebeen going for about 40 years, so it's easy to forget the worries of the first couple of trips, but just take it steady, don't try to go too far or do too much, have a fe w words of French if you can - every little helps - Above all try to relax. In all my visits i have rarely found anyone unhelpful or out to con you, the roads are much less congested than here - except in big cities. There tends to be a mad dash at midday and again at 14.00 going to and from the midday meal, so be careful at these times. Mosty campsites take the CCI card instead of your passport. the convention is you pay the evening before you go, but off peak i havenever found any need to be too specific about how long i'm staying.
