Sproket said:As your Freelanders max weigh on the towball exceeds the max of the van, you can load it to a max of 100kg nose weight. ...don't exceed it ....
By experimenting with different nose weights you will find the best that suits your needs.
Sproket said:If it tows well at 85kg use that as a base till you go farther afield and gain more towing experience. ..it's quite easy to get another 15kg on the nose ..
The 100kg max nose weight is for the alko chassis. ...
The coupling is designed for a big range of products / trailers well as being used for a caravan ...
SmnByt said:However I have a Knott chassis not an al-ko one
Sproket said:Just to change the subject a little to your question about movers....
Make sure that whatever model you buy will fit that type of chassis ....
FYI ๐
Axle movers are engineered to clamp on to modern AL-KO and BPW chassis without any drilling, which is not permitted by the chassis manufacturers as it would weaken the chassis. Other caravans such as early Lunar models with an alloy Knott chassis or specialist makes of caravans like Eriba and Gober may need additional brackets to facilitate the mover installation. For such specialist caravans you will need to consult the mover manufacturer.
Damian-Moderator said:Quote " However I have a Knott chassis not an al-ko one "
Knott also have a 100Kg weight limit.
Damian-Moderator said:I was until recently a Service Engineer for Al-Ko and Knott/BPW, amongst other manufacturers.
SmnByt said:Ah, So its the chassis/ Drawbar that has the 100kg limit on it?[/quote
It is assumed that you are referring to the caravan A frame when you are referring to the "drawbar".
on the fitted coupling there is usually a 100KG max if its an ALCO chassis but as said the hitch down loading is governed by the lowest fig between the caravan & the car, If your new hitch / coupling max exceeds the original hitch /coupling max then I would stick to the original hitch max
