Hook ups
Jun 22, 2007
102
Travelling to Germany,Austria and possibly Italy With regards to these countries do they all use the same 2 pin hook up as in France or the Uk style 3 pin or a mixture or is there something different required
Feb 1, 2010
52
A mixture I'm afraid, and take a Reverse Polarity checker just in case.
If you get stuck; sites usually have a spare that you can have/rent, or leave a deposit on.
Jim.
938
You have to be really off the beaten track to encounter 2-pin hook-ups in Germany or Austria. By far the majority have the same 3-pin connections as in the UK. I don't know when I last came across a 2-pin hook up in Germany, and I live there.
Apr 1, 2010
860
Actually we have come across some. Here in Southern Austria where we are at the moment is a 2 pin plug and Reversed Polarity. So you do need a selection of adapters.
938
If it's 2 pin, how do you know that it's reversed polarity? There is no set way in which the leads are connected to a 2 pin power point because the plug goes in either way round.
Jul 15, 2008
3,925
1,114
......perhaps DianneT has one of these and it is not possible to rotate it 180deg due to the confines of the supply post!
Apr 1, 2010
860
Yes we have and there are 3 UK caravans here at the moment and they have the same. We have a, plug in, Polarity Tester which also tests earth.
938
Yes, that would explain it. However, there is no standard in Germany which defines which way round the leads should be connected in the power socket. As there is no 'right' way and no 'wrong' way, one cannot logically refer to reverse polarity in this system.
Jul 11, 2006
490
The curious bit is that the CEE017 plugs are actually marked L and N but outside th UK no-one seems to take any notice of it.
Lutz, in the UK we use ring mains and single pole switching on our outlets, hence it is important to know which is the live connector. In most of Europe sockets are radially wired and appliances double-pole switched, so polarity is not so much of a consequence.
938
Theoretically, even on the Continent they should connect L and N the right way round on a CEE plug, but probably some electricians figure that if it's not important which way round on a Schuko (Continental) plug, then why bother on a CEE plug.
I don't know of any appliance in our household that has double pole switching. All that I have had cause to open up to have a look inside were single pole.
