My wife and I both dislike using 'On Site' shower arrangements especially when it's cold and raining. Unfortunately, the Carver 9 litre, gas only, storage water heater, fitted in our van, is unable to give us both a decent shower in quick succession. However, I notice that Morco now supply a Room Sealed instant gas water heater [Morco F-11E] which would supply constant hot water and is similar to those units fitted in static caravans. With the advent of the 'Super Pitch' [ie electric, mains water and sewage disposal on the pitch] the F-11E would be the answer to the cold shower problem. The F-11E is 'Room Sealed' drawing air, for combustion, from outside the van and if properly fitted and maintained no propane or carbon monoxide should ever leak into the van. A variety of flue configurations are available. The maximum propane consumption is 1.7 KG per hour and is capable of supplying up to 5 1/2 litres of water per minute at 50 deg C., temperature and flow are both adjustable. The F-11E requires a 240 volt supply that can be mains or can use a 50 watt 12/240 inverter. The minimum water pressure required is only 0'18 Bar [3 psi] so well within the capability of a good 12 volt pump. Morco offer this unit to cover a wide range of uses, home, boats, caravans and motorhomes etc. It would, of course, be necessary to keep the old Carver for use on non Super Pitch sites. Apart from the price,
