Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
We’re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. We’ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
I have just had my first winter with a caravan. When I was putting it away for winter i drained the water from the system but failed to drain the water heater, this looks like it has resulted in a leak which could be costly to repair.
Are there any other things that I should be doing?
Read this and your other post re your water heater leak. As you now know draining the water system should include draining the water heater as well. When draining down you should leave all the water taps open.
Another water system to drain is the holding tank for the rinse water for the onboard toilet.
