I have noticed in our washroom that we have a strong urine smell, concerned I hadn't cleaned out the cassette correctly I re cleaned it, I also then went on to clean the whole washroom with no effect to the smell.
after looking around I seem to of traced the smell coming from the area in which the cassette is stored. When you pull out the cassette it reveals a plastic bottom with a drip panel and an area to store some small bottle of blue and pink chemical. Anyway the smell seems to be coming from underneath this plastic bottom but the only way I seem to be able to get access to it is by removing the whole toilet and shower tray.
I have noticed the area in which you store your chemicals has a couple of hole's and i'm guessing some how that some urine has dripped thru. I've kept spraying cleaner into it and it has helped a little but not removed the smell totaly.
I'm not sure how the urine has dripped thru unless one of the kids has used the loo whilst I was away emptying the cassette but i would of noticed splashes of urine in the compartment when i returned the casstte and it is an area that we always wipe clean so again would of noticed. the only other thought is if the rubber seals are maybe a little worn on the cassette and as i've pulled out the cassette for emptying whilst full a little has come out of the cassette and dribbled thru to the underneath of the plastic bottom?????
Any advice or recommendations appreciated.
Thanks.
Thanks.
