Can anyone help? I have just picked up a Hymer Living and would like to use a Porch awning for weekend trips. We bough a Scenic Plus but it was too short (Height of Caravan is 251cm) Can you recommend a suitable awning?? Thanks
I use the Isabella Magnum with reasonable success, however you need to be carefull on how you pitch. Its only just long enough in the drop so ensure you avoid pitching where you need a wedge under the door side caravan wheel. Also avoid a longitudinal slope as that also causes one sidewall to be on tiptoes. Otherwise its excellent.
As the Ventura vesion is similar that might be a cheaper option if cost is an issue.
