hyundai abs brakes
Apr 9, 2005
118
when the abs brake light comes on, and the rings are cracked, is normal breaking still alright, for a sente fe, y reg ( 2001
Jul 26, 2005
575
As a general precuation on any car with ABS if the light comes on when driving you should get it checked out by a competant fitter with the correct fault reader - which probably means a Hyundai dealer.
Your handbook probably tells you to drive with caution and go to a dealer ASAP which is sound advice - faults can range from simply a dirty speed sensor through to major electrical and pump failure.
Don't understand what you mean by "cracked rings" but if you mean you have a cracked brake disc then that is really serious and the car should not be driven under any circumstances - are you sure it is the ABS lite too? If it is a pad/disc warning lite then that is just as scary with "cracks"
Don't take a chance with brakes - get it checked!
860
I think Judy means the 'brake shoe' symbol of the brake warning light. If that comes on as well as the ABS light, it does sound as though there is something seriously amiss that needs to be looked at post-haste.
354
Dont take any chances with brakes, get it checked ASAP, and if you are in doubt dont drive it. I had a servo go on me many years ago, was absolutely terifying experience, pedal went rock hard.
Apr 9, 2005
118
sorry, should have put the rings are cracked on driveshaft, its just the garage where i have brought it from, has really dragged his feet in getting the work done, even though i have only had the car less than 3 weeks.Have been to hyundai garage and been told by them to get the work done asap.Hopefully tomorrow the work will have been done
