looking at www.whattowcar.com, ASSUMING it's a 2ltr diesel Tuscon, they give the match 5 stars and say:
"The match between car and caravan is perfect in accordance with a mix of European standards. However, according to the British Towing Code the percentage (loaded caravan / kerbweight tow car) is 77%.
The towing performances of this Hyundai with your Abbey are perfect (performance index = 105 km/u or 65 mph).
You may expect excellent performances from this outfit. On flat roads it's easy to come along, in which case top gear is applicable in all cases.
On motorway inclines you will be able not only to come along, but be the first at the top. On steep roads you have more than sufficient power to keep going. On hill starts there will be more than enough power to get going, provided the wheels have traction."
have a look yourself in case I have picked any wrong options. Best of luck!
Mark (",)
