In coming water temperatures
As we come into the colder part of the year, I find my instantaneous water heater struggles with the incoming water temperature, its designed to work with a 15 degree incoming temperature, I use a 40 L aquaroll with a float from the mains hook up to keep it constantly filled, have the barrel rised off the ground to stop the cold getting into the barrel, but with the water coming in at 8/9 degrees it’s hard , someone suggested putting a heater in the barrel, like you see in a fish tank , any other suggestions would be most welcome
I wonder if the instantaneous water heater is simply not designed for UK temperatures as the average UK temperature, over a full year, is only about 10 degrees C which will be the average water temperature coming in.
Putting a heater in the barrel would be very inefficient, wasting most of it's energy to the atmosphere.
You could fit a supplementary water heater between the cold intake and the instantaneous heater.
Hi and welcome to the forum.
One of the forums members has already gone through a similar exercise, unfortunately I can't remember who it was, but I suspect he had a differnt heater in the caravan as he was looking to raise the external tank above 15C.
When posting technical questions it can help us a lot if you can provide make model and year of caravan, and similar information about any specific appliances your query may be about.
I suspect a fish tank heater and thermostat may be all you need. It would be best to have an adjustable thermostat. If you were to insulate your water barrel it would improve the efficiency, and of course would help prevent freezing.
It was Grey13 who put a lot of time into producing a system with additional heating so that he could enjoy longer showers. Last post was around time he was heading to italy with a new Jaguar F Pace tow car.
A search of his posts will highlight what he did. Look at “heater” by Grey13 and there are two detailed threads come up.
Reactions: Mel
Remember that increasing the barrel water temperature will increase the temperature of water from the cold taps.
I think a previous suggestion of fitting an inline heater between the supply to my heater and the cold sounds like a good idea, would be easier to regulate, but it’s finding such an item is the trick!
In line water heaters are available from aquarium stockists and are used on tropical fish tanks etc,as are various heaters that incorporate a thermostat usually Upto 500 watts (approx upto 32°)
Yes but they are designed to heat a fixed tank , not one that is constantly being topped up with cold water, from research it would take a 4kw to 6kw inline water heater to bring a constantly flowing tank from 10 degrees to 15 degrees, and couldn’t see many site hook ups withstand that amount of electricity
Thank you ,
To be honest this has only been a problem developed last week, and maybe it’s a sign to wrap up for the year , the caravan itself is getting cold at night , and we have had a good run this year despite all the storms. Caravan is home and will start clearing it out for the winter and get the cover on , and let it be a problem for next year when the season starts again
In the winter we would normally run the water heater on gas and electric at the same time, kept the caravan at 15c during the night.
Oh and padded covers on the aqua rolls.
The air pressure fault is a sign the water is boiling , producing small pockets of steam causing the boiler pressure to jump up ( this effect is known as kettling and is a sign of low water pressure within the boiler) , if this is the case you may be be losing temperature in the pipes from the boiler to the taps , insulating them may help with a greater flow. An instantaneous water heater is designed to work with incoming water pressure of about 2 bar, external water pumps struggle to achieve when water is flowing. Fitting an internal pump would give greater pressure whilst water is flowing and not cause the water heater to struggle or kettle .
But the greater the flow , the cooler the water becomes, I’ve tried it with a 30psi pump and a 20 psi pump and the 20psi was the only one that flowed slow enough to let the water heat , yes 2 bar would be ok in a hot climate, but not in the uk , the instantaneous heater is brilliant, to have a proper shower in the caravan is amazing, but its downfall can be our water temperatures , and no matter what I do I can’t fix that , as for losing temperature, the shower is the farthest tap from the boiler and it always works perfect, why I’m baffled , I can have a 40 degree shower without a problem, just have to accept beyond October the water is too cold , as is the caravan for that matter
In an instantaneous heater the boiler fires the minute you open the tap , there is no storage in them , ie why they are called tankless heaters, you have a constant flow of hot water, not like the traditional boilers where you had to have an army shower of on, off , on off for the fear of running out of hot water
Previously we had the instantaneous type of heater in our home and it worked off two 45kg gas cylinders. It was brilliant even when the temperature dropped below 0C however water was obviously mains water. I was not aware that they were available for caravans? Sorry I cannot offer anything helpful.
I mass in Germany have developed one that is type approved for caravans , is a great piece of kit , love it , you set the temperature you want if your going to the shower and just keep the tap open at full hot , has took a bit of messing about with, but works brilliant, just doesn’t like our colder months, but season ends in October, which this year was very unseasonal !
If it's developed in Germany but can't cope with a British autumn, let alone a Northern European winter, it's not that brilliant!
Have you contacted the manufacturer and asked for advice?
The specifications for the IMass heaters gives a water temperature increase of 37.7 degrees C so should be more capable than you're experiencing - the reference to 15 degrees isn't a minimum but a standardised temperature to quote performance.
So I wonder if it has a fault or the settings are wrong?
When I had a Paloma water heater on the boat I don't remember struggling for hot water even in the winter. I did however have to turn it to its hottest setting and the water flow was pretty minimal, just about enough for a shower using hot only, there were no thermostatic valves back then.
