Has anyone got any experience of these plastic pads that go up against the caravan? Attempted to put the awning on the caravan (for the first time) at home before using it over the easter weekend and got confused with what the instructions appeared to tell me with what i could actually do. On the diagram it appears that the pad should fix onto some form of bead and then the tension from the pole would hold it in place against the caravan. However i can not find any bead or place to feed through the top of the plastic so therefore reverted to just using the tension of the pole to hold it in place. Not really sure if this is right or not. Any help greatly appreciated.
