Hi Guys
Just got the van out of storage and the turn right indicator has stopped working.Change the bulb with the left side and the fault stayed on the right,so its not the buld.
any ideas
937
scott, give the van plug terminals a good clean and spray with WD40, or similar, and with a small bladed flat screwdriver, restore the gaps in the pins, as they often close up during use.
Clean your car sockets and spray with WD 40 , or similar, as well.
4,473
Hello Scott
Corrosion is the most likely culprit, If possible chcek all the wire terminals inside the lamp housngs - these are usually spade type connectors. Pull off the connectors one at a time, a quick spray with WD40 and push the connection back on. That usuallyb does the trick
Hi Guys
Just an update..got my neighbour to connect his car to the van and hay presto it worked.so the fault is with the car.Good news as I dont need to tow the big white box about to get it fixed.
