indicators
Jun 28, 2010
12
hi chaps.
my n/s indicator on my van is'nt working, ive checked the plug on the car and cleaned up the terminals on the light cluster and tried new bulb , still no joy.
anything obvious you can think of please?
cheers
garry
936
Have you checked the plug on the van and the fuses for the road lights inside the van
Jun 28, 2010
12
hi damian.
no, havn't done either, thanks for that.
its literally only the indicator that dosn't work tho, that wouldn't just have a fuse for itself would it?
Jan 21, 2007
18
Hi Garry, i had the same problem a while ago, it 'turned' (sorry) out to be the audible indicator (buzzer) which was located in the boot, apparently it was'nt letting enough power through to opperate the indicator although the other side worked fine. a new one from local car spares shop was about £4.00. replaced and sorted......hope this helps..
936
Yes it would, usually there is a multi fuse block under the front seat or bed box with a fuse protecting each light system, left indicators, right indicators, front and rear marker lights etc
Aug 6, 2010
117
I had the same problem on my new van, the fault was the silly ring of black plastic with the electrical connections that retained the bulb in position.
I replaced this ring and cable tied it in position to prevent it from coming out, I did both sides and had no problems since.
