Induction v halogen
Sam Vimes
2,495
1,998
11,935
I must admit that I like induction but a bad experience with our home range cooker put me off them. When we fitted out the kitchen we got a top end range cooker with 6 induction burners. Very nice to use while it lasted.
True to form a couple of months after the warranty expired there was a loud crack from the cooker and the circuit breakers tripped. In the hob were three control units, one for each pair of burners. One control unit had literally gone up in smoke.
I got a replacement at about £400 and fitted it myself. A bit tricky but do able. It didn't work for very long before giving an error code..... reboot and it would work for a while. I managed to get hold of one of the engineers at the manufacturers who confirmed that the error code indicated it was dead and would arrange for me to get a replacement f.o.c. I fitted that and all was well - for a few months.
A few months later another control unit went the same way. Not prepared to spend more money on something that wasn't going to last we replaced the whole cooker, this time with gas burners. Sure it cost a lot more than the control unit but its still working after several years. A lot simpler than induction.
Maybe I was just unlucky.
5,154
Oh dear we have a Range cooker, but it is only about 2 years old. Our Beko stove lasted about 8years before it gave up the ghost.
Sam Vimes
2,495
1,998
11,935
I think I was just unlucky. Failure rates are based on statistical evidence and like buses you can get three come along quickly then nothing for years.
8,948
Three years ago not long after moving into the house we had a new kitchen, out went the Range and we discussed all of the variations from electric, gas high level etc. I the end we opted for an AEG free standing cooker with gas hobs, ovens but an electric grill. Basically because we had used gas cookers ever since we got married and they had never given any trouble , the AEG came with 5 year warranty and gas was cheaper to run than electric. In parallel we had a new kitchen fitted in our daughter’s house. She opted for electric cooking appliances and the hob was induction. She’s had a few problems which now seem to have been resolved. Nuff said, or should it be Neff said😂
5,232
Back to the OP.
These can be used in the caravan but are very power hungry.
Bear in mind the pots and pans needed are also very heavy and will erode your pay load margin.
Realistically imo stick with all gas hob or 3 gas 1electric ring in the caravan. At home is totally different and something for discussion on a new page. I’m up for that Clive 😉
Reactions: alamo16584
Apr 23, 2024
427
342
935
Re finger ( and other places these days) rings, they should not be placed near the induction hob , lovely way to lose a finger ( as an apprentice I used to use RF induction heater to activate barium getters in CRTs - 20 to 600 Deg c in 3 seconds - scary) they are now available to heat up rusty nuts on old cars
2,595
Not heard that warning before or had a problem, probably due to gold rings.
653
303
2,135
Back to the OP.
Only need max power to get pot of water boiling(2min) after that reduce power/setting to few hundred watts, no different than normal electric hob.
My non stick frying pans are lot lighter than old non compatable copper&stainless ones. Didn't need to change pots which aren't overly heavy.
Once you've used induction there is no going back and it is lot quicker than gas to boil pot of water. Also don't have to worry about gas fumes in confined space. In saying that I'd still be venting kitchen if cooking just for steam and smells.
I bought touch control hob for house as its easier to clean. Down side is odd water spillage can upset it along with wet finger. Knob control one next time.
4,277
Back to the OP.
The one I have was an Aldi 2kW (peak) special buy at about £30 a number of years ago, still going strong. Only problem I used a frying pan on it, and th eedge of the pan slipped across some of the plastic surround and started to melt.
2,553
When we put our new kitchen in nine years ago we went with induction and so far no problems .
Sep 10, 2024
5
1) Go with infra red, running cost similar to induction, no new pans needed, and safe to use..
2). Ceramic and hot plates expensive to run but, new pans not needed,
3). Induction not good for folks with health issues. and I’m not buying new induction capable pans. Also power hungry on start up and done work on some European campsites, that run 6 amp supply’s.
Been proven on which magazine. Infra red is way forward
4,277
2). Halogen expensive to run but, new pans not needed,
Cooking with electric hobs has evolved. Where as the oldest form of electric hob used resistive heating elements buried in either coiled sheath, solid hot plate, which slowed the heat up and cooling times of the plate, and made regulating temperatures for simmering quite difficult, the advance to halogen or infrared heating elements helped with their more rapid warm up and cooling which you could see, neither is as rapid a an induction hob, where the heat is only generated in the base of the cooking pan, and changes of the input control can be seen within a few seconds rather than tens of seconds. You can catch milk at its boiling point before it overflows. - even faster than working with gas cookers.
Whilst induction hobs do need pans with a ferrous(Magnetically attractive) base to work, as the popularity of induction has increased many pots and pans purchased recently may already be induction compatible. many aluminium pans now include ferrous materials in their base to enable cooking on induction hobs. You can check your pans with a magnet, if the magnet does not get attracted - they wont work on induction hobs.
Costs of operation will depend on a lot of factors, but theoretically becasue of the way induction hobs only heat the ferrous base of the pan, there is less wastage heat passing up the sides of the pan, thus any inefficiencies of running the emitter, are broadly offset by not unnecessarily heating the hobs surface and surrounding structure, or the air around the hob surface.
The only health concern I am aware of regarding Induction is for those people who have heart pacemakers, and the risk is actually quite low unless you unusually close to a working emitter. So its fairly specific health conditions not as widely hazardous as implied by your comment.
As for power consumption, that will depend on the exact model of induction hob you choose. Some can operate at about 1kW or 4A. But that will depend on how the control circuit is implemented.
Whilst there are a number of mainly continental sites that only offer 6A EHU, the camper/caravanner will probably be aware of they when they book and should already be ensuring they shed load where possible to avoid tripping the excess current breakers.
This might look as though I'm proposing induction hobs, but its more the case I dislike seeing information being misquoted or skewed without a balancing argument or explanation being made.
I don't recall Which? doing a halogen vs Induction comparison, and I couldn't find a link to such a report on their website. Can you identify year and month of the report please.
Sep 10, 2024
5
Came across that article on ( which magazine online ) last year, when we were replacing our Gas hob to go to electric. Infra red was 80 % efficient no health issues and no new pans. and induction was 90% efficient but magnetism causes health issues, the old hot plates was 40% efficient.
I didn’t save it sorry.
Induction is Same as they used to say diesel cars were the cleanest around, Oooops now they are the devils fuel. Diesel particles are dangerous
Infra red is same as sunlight, just don’t stair at the light.
Induction is magnetism why do they don’t want you in mri or ct scanner to much, magnetism affects the body.
2,595
By infra-red do you mean ceramic? I cannot find a mention on Which, and Google brings up Ceramic.
We had a ceramic many years ago and hated it. Very slow to heat up and hard to clean. But that was a long long time ago. The may well have improved in both respects.
5
3 types of electric hob
1) hot plates which then developed into ceramic tops ( like a large electric kettle ring under the hot plate or ceramic tops.
2) infra red / halogen which is basically a large bulb that release infra red light to cook the food, a bit like sunlight. More natural heat
3) induction which uses magnetism to heat pan which then cooks the food, magnetism can interfere with body’s health, Drs don’t like exposing you to mri or ct scanners unless nessesary, due to long term health issues. With magnetism.
5,154
Is this when you switched on your induction hob. :)
PS: I thought you had battery back up for your internet.
Correct, but no broadband signal is no Internet which is why i think the issue is prior to our router.
4,277
I'm sorry but your comparisons of induction heating to diesel, and medical examination processes do not make sense. A CT scan uses ionising radiation like x-rays , But MRI's do not.
There are some similarities between an MRI scan and an induction hob, in so far they both produce magnetic fields to make other magnetic material react, but there are important differences between them such as the strength and frequency of the fields, which in an MRI are much more significant, and will produce a significant magnetic resonance responses at a cellular level, which if sustained might damage some cells. That is why MRI's are carefully metered.
The other risk in an MRI examination is any magnetic material that is not properly restrained can literally become a projectile in the examination room. Similarly some patients that may have received injuries involving metal debis, would be carefully assessed to see if any such particles might be a risk to the patient or the equipement.
They can't risk inviting other people into the room, incase they get injured, or they might introduce some non restrained magnetizable items. There is also the noise produced by an MRI scan. It is also a health hazard, which is why the patient is provided with hearing protection whilst the examination is undertaken.
Induction hobs do not have such a profound extended effect except when items are in very close proximity to the emitters.
When used correctly, an induction hob does not present any hazard to people, except where they may have medical implants that might be disrupted if they are brought to close to an induction hob.
Its fair enough to raise the concerns, but it s also necessary to make sure those concerns are not overstated or unrealistic.
Sam Vimes
2,495
1,998
11,935
While it's useful comparing the efficiency of different electric hobs, cost comparison between running costs.... electric vs gas are also worth noting.
Per kWh electricity is 3 or 4 times more expensive than mains gas and 50% more than propane.
2,595
Yes, but induction are soooo much easier to clean.
4,277
Whilst the price per kWh of the various energy sources are of course important, but the way the energy is converted in to heat and its applied to the substance you want to heat is also very important.
With Gas rings (Nat Gas or LPG) to maximise heating efficiency you should carefully match the size of the flame to size of the pan. Having the fame turned up too high means there is an increasing amount of gas used that is effectively wasted as it pass up the sides of the pan/kettle. There will always be some hot bypass gasses which means efficency is low.
Similarly with Halogen and the earliest coiled contact elements, if you can see any of the halogen light or the contact surface of element, that mean heat produced in those visible areas is wasted.
Induction hobs react to the presence of the magnetisable base of a saucepan, and the energy is concentrated to it, so its less wasteful than almost any other system.
Just as an indicator, if you heat a pan of water, on an induction hob, you will see water vapour rising above the pan well before it actually boils. Put te same pan on a gas ring, and you will barely see any water vapour until its boiling. The reason is with an induction hob, the heat is only entering through the reaction of the pans bas to the hobs emitter, and there is very little warm air rising around the pan. This means the air around the top of the pan remains considerably cooler which allows water vapour to form into its visible phase much sooner.
Gas hobs have so much hot exhaust gas bypass that the air around the sids and above the pan is much warmer, which does two things, it increases the airflow velocity above the pan diluting any water vapour, and its heating it which prevents the water vapour from condensing into visible vapour so early.
The inefficiencies of high exhaust bypass from gas rings, and to slightly lesser extent of halogen and electric rings when using under sized pans, might well change the overall cost effectiveness of all the energy sources by quite a lot.
