Hi all, I'm new to this forum so please accept my apologies If this question has been asked before
I want to install a leisure battery so that I can go off grid.
My van only has an EHU and no existing battery system installed.(German van)
My question is this:-
How do I actually connect the battery power into the existing wiring in the van?
I have a dometic system with an RCD and two trip switches and two 15A fuses and it looks like a built in step down transformer that does 240V down to 12V.
Splicing into the 13pin cable that connects to the car (via the terminal box) is probably not an option as I only have a 12N(only the external lights :brakes, indicators, running lights) therefore I figure that there are no links to the main dometic board. Besides, I'm not too bothered about charging the battery while the car is running.(I might do that as an upgrade at a later date)
My plan is to use solar to charge the battery(ies) with a charge controller, therefore I shall have enough power to also use the sockets for my laptop, kettle etc
I also will need something that will allow me to switch between battery power and EHU, whether manual or automatic, so suggested options for this also would be appreciated
Many thanks all 🙂
Many thanks all 🙂
