Interior Rubber around Door Opening
Posted before with no replies, trying again.
The rubber/fabric around door opening has curled up at one point.Tried glueing back into position maintaining pressure but without success. Has anyone any idea what will hold the surround in place?
Janet
Can you post a photo with your problem & maybe someone who see's it will know how to sort it......
How To Post Photos ( ten easy steps )
Try gently warming with heat gun on low setting or failing this use HID's hair dryer when she's not looking. While material is soft and plastic, put some contact adhesive behind it and hold in place for a few minutes.
Be careful, as too much heat will melt.
can recommend hairdryer method, we had to do this earlier this year . Moulded trim round the door while warm and stretchy and its still good.
Thanks everyone. Will try the hair dryer, thinks it should work but not sure which adhesive will be best.
