- Jun 16, 2020
- 5,904
- 2,810
- 17,935
19.99 for 10 litres. Saw it when I went up to collect a “ hydro snake” for my daughter.
I think that might be 1p cheaper then🥹. Every penny counts!
Yes but it’s not just 1 pence as it was £19.99 for 10 litres not 20 litres at my local Screwfix this morning.I think that might be 1p cheaper then🥹. Every penny counts!
Why not keep five litres in the car so that when the warning lights show fir low level you can run it right down then start to replace with a quantity more aligned with your usage. I assume on a Jeep it can be replenished by the owner quite easily.Let me rephrase that. Service book states "completely fill Adblue tank" which I assumed meant they top it up. I understand what you are saying about shelf life and it makes sense. Maybe they are expecting the adblue to be nearly finished after 12500 miles> I wonder if it is possible to drain an adblue tank?
Seems like i get some Adblue from halfords from now on for my car when it needs a some more thanksHalfords Adblue is £20 for 10 litres - I paid £32 online for 2x 10 litres recently.
Some garages do have it available on pump, much cheaper.
Thanks for the link. They probably do it at every service as they know it is unlikely that you will use up the 8 gallons in 12500 miles? Just a thought.Why not keep five litres in the car so that when the warning lights show fir low level you can run it right down then start to replace with a quantity more aligned with your usage. I assume on a Jeep it can be replenished by the owner quite easily.
Here’s a link that gives some useful information but doesn’t cover life once installed in the vehicle. Some sites quote 6 months in vehicle life. Which seems at odds with the top up frequency aligned with annual service intervals. But at the end of the day if it doesn’t work at optimum you will just emit a bit more NOX.
Greenox Solution > AdBlue® > Handling
AdBlue® is a 32.5-percent aqueous reduction solution of the highest purity. The ISO 22241 standard ensures consistent quality. AdBlue should ideally be stored within a temperature range between 0 and 30°C, and kept protected from direct sunlight. It should be properly sealed when it is not being...www.greenoxsolution.co.uk
However regarding the OP I think I will take the Jeep top a local fitter to see if they can identify the towbar which is probably a rebranded towbar.
The issue if the Adblue goes "off" isn't just that NOx levels will rise - it's mainly that the Adblue starts crystallising and blocking the pipe/injector necessitating complete replacement.Why not keep five litres in the car so that when the warning lights show fir low level you can run it right down then start to replace with a quantity more aligned with your usage. I assume on a Jeep it can be replenished by the owner quite easily.
Done that check. We never store ours there as a hassle arriving at caravan and then realising you have to empty the rear to lift the floor board to access the tow hitch. Once was more than enough!Just a thought the previous owner hadn’t stowed the detachable part in the boot underfloor storage area. That’s where mine lives in a custom stowage.
Am I glad I changed both cars to petrol plus chain cam some three years ago. 😂The issue if the Adblue goes "off" isn't just that NOx levels will rise - it's mainly that the Adblue starts crystallising and blocking the pipe/injector necessitating complete replacement.
And probably glad you didn't get a direct injection petrol as they have their own set of issues.Am I glad I changed both cars to petrol plus chain cam some three years ago. 😂
That's for storage in a sealed container - once you've refilled with Adblue and spilt a bit, you'll see how quickly it crystallises in the open air.Referring back to that link regarding grades of Adblue it states that if ambient temperature is about 10C or less the fluid should be okay for a minimum of 36 months or have I misunderstood? Totally new to this Adblue thingy!
I can remember smell of leaded fuel in the cities in the sixties and severnties.And probably glad you didn't get a direct injection petrol as they have their own set of issues.
I reckon 1990 cars were the sweet spot, just before catalytic converters were mandatory - but then CO2 would have been much higher.
I can't say I noticed anything different when we switched from leaded petrol to unleaded.I can remember smell of leaded fuel in the cities in the sixties and severnties.
I lived in the middle of Hillbrow, Johannesburg in the seventies and it was a horrible smell. Many years later after they switched to unleaded when I went back, no smell, but even more traffic.I can't say I noticed anything different when we switched from leaded petrol to unleaded.
That referred to Adblue stored in its container. That’s why I added the comment about some websites quite 6 months in the cars tank.Referring back to that link regarding grades of Adblue it states that if ambient temperature is about 10C or less the fluid should be okay for a minimum of 36 months or have I misunderstood? Totally new to this Adblue thingy!
My Subaru is a direct injection engine and they don’t show any unacceptable trends on reliability websites I’ve looked at. Given that catalytic converters became law in 1992 in UK your really referring to 1980s engines. Given the choice of a 1980s engine and one of the modern petrol engines I know where my choice would lie on performance, economy and quietness.And probably glad you didn't get a direct injection petrol as they have their own set of issues.
It really cannot be a big issue as millions of vehicles in UK, Europe and around the world successfully run their cars without any concerns. Methinks too much thinking isn’t necessarily a good thing.
PS Since it’s two thirds deionised water and one third pee I wonder what it does in very cold temperatures 😱
Thank you, my comment was TIC but a definitive answer is always welcome. ❄️It freezes - which is why all Adblue systems have heaters.
