Hi All,
As some of you may be aware we have over the last 3 years or so had numerous problems with leaking windows. The result of which we ended up with a replacement caravan.
I have started a new topic with this as the inotial problem seems to have been solved. We do however have a continuing issue with the water tightness of our side windows.
My question is does anybody else suffer from water getting between the acrylic windows and the rubber seals?
We have had all the side window rubbers replaced and refitted to Polyplastics latest recommended fitting instructions by Swift at their factory (this was after we had suffered water collecting on the window frame and entering the van). All looked OK till the next lot of persistant rain (not windy). When I went to check the seals there was water evident between the acrylic and the rubber. I was not happy!
Miriad (Polyplastics UK distributer) claim that this is perfectly acceptable and not to worry. What are your thoughts? My view is the window seal should be water tight against all normal weather conditions that we experience.
Cheers
Andy
Cheers
Andy
