JLR D3 and Range Rover Sports - Detachable Tow Bar Lock
Jun 4, 2019
18
4,515
Anyone know why JLR changed its detachable tow bar lock from a small handle to the larger handle with its ratchet on the inside.
Sep 21, 2007
258
16
18,685
Land Rover did have some issues with tow balls becoming detached, could be something to do with it.
3,907
1,649
As said, it was a feature introduced to help with an issue they had where if the bar was left in place, then the endless jiggling about lead to wear of first the securing pin, follow by the tange/receiver. This caused towing "knocks" and these further damaged the receiver.
The ratchet moulded in the green knob helps stop any unwanted loosening of the locking pin.
If you buy a D3 with a bar featuring the smaller ratchet less knob get LR to check the fit with their test gauge, just a few minutes job and was a "recall" . Remove it when not actually in use, and listen for any knocking in use.
With moderately fretted receivers, LR change from the removable to their fixed tow bar, with badly fretted receivers, they cut out and replaced the crossmember.
I had the knocking with our D3, and LR retro fitted the fixed one, I did though tend to leave it installed between jobs. I have no issues with the D4 and later plastic ratchet type removable towbar, but it has never done any miles installed and not in use..
Reactions: Beachball
Jun 4, 2019
18
4,515
OK,
Having the early smaller version of the locking handle on the Tow hook.
I purchased both the later larger version of the locking handle with the built-in ratchet.
The parts are interchangable providing both parts are used with no drilling etc.
