Jockey Wheel change
Feb 2, 2024
161
28
585
Hello i am wanting to change the plastic maypole wheel which is blooming useless on gravel pitches to a solid rubber one any advice on what i should as minimum replace it with on my Baily Pegasus Grande SE Bologna 2023 model
Jan 19, 2002
1,706
547
To order online you need the overall diameter, the axle diameter, and the width of the wheel across the axle and lastly the widths of the ‘tyre’. Then you should find plenty of suppliers for you. I did mine recently but failing to measure the axle width I had to use a couple of metal washers so that the new wheel remained central in the bracket!
Reactions: West Riding lad
4,592
The solid rubber ones, that "Look" like inflatable ones seem to be best for gravel.
Feb 2, 2024
161
28
585
thanks all for input but i sorted a replacement from Bailey dealer where i bought the caravan...appreciate responses
