- Mar 14, 2005
- 420
- 0
- 0
When the jockey wheel is not being used to manauvre the van should it be put up or can it be left dowm when on site and in storage or does it not really matter either way? Just curious?
Actually the reverse is true. The weight of the van is taken on the wheels including the jockey wheel. That is how caravan chasis are designed. Quote from Alko "Corner steadies are designed solely for the purpose of steadying the caravan corners on-site." They should be wound down enough to "steady" the van with the weight remaining on the wheels.when you think about it,if the steadies are solidly on the floor,then theres very little weight if any at all on the jockey wheel so it doesn't really matter whether its up or down,its a matter of choice
sorry alistair but i must disagree,the steadies MUST NOT BE USED TO LIFT THE CARAVAN SIDE TO SIDE AS THIS MAY TWIST THE STEADIES,but when putting down the corners on site you always make sure they are solid with no movement felt when moving inside the van.lets face it,if all the weight is on the jockey wheel the front corner steadies are not doing there job, ie, steadian the van. try this at home with van and i bet u the weight of the van on j wheel is different.put jockey wheel on scales,then put down steadies solidly and the weight differenc will show lighter. not the same, or heavier.im sure your caravan must move around when in use????Actually the reverse is true. The weight of the van is taken on the wheels including the jockey wheel. That is how caravan chasis are designed. Quote from Alko "Corner steadies are designed solely for the purpose of steadying the caravan corners on-site." They should be wound down enough to "steady" the van with the weight remaining on the wheels.
If that was the case, what happens in caravans with rear dining areas, or continental 'vans which have the reverse layout to ours? Or fixed rear bed 'vans where people would spend a lot of time rear of the axle.Always down when the van is in use. The weight should be on the axles and jockey wheel, not the corner steadies which are only there to steady the van, not take the weight of say several people sitting at the front of the van.
You've obviously missread what Alistair said. At no point has he said use the steadies to lift the caravan, you use the jocky wheell to level the van front to back and if needs be use blocks first for level left to right. Once the van is level, the steadies (NOTE there called steadies not supports or Jacks) are then lowered for stability, these are the clear instructions from the manufacturers.sorry alistair but i must disagree,the steadies MUST NOT BE USED TO LIFT THE CARAVAN SIDE TO SIDE AS THIS MAY TWIST THE STEADIES,but when putting down the corners on site you always make sure they are solid with no movement felt when moving inside the van.lets face it,if all the weight is on the jockey wheel the front corner steadies are not doing there job, ie, steadian the van. try this at home with van and i bet u the weight of the van on j wheel is different.put jockey wheel on scales,then put down steadies solidly and the weight differenc will show lighter. not the same, or heavier.im sure your caravan must move around when in use????
