Jockey wheel
May 28, 2025
20
17
Another question for you regarding the jockey wheel and clamp: when you're ready to set off, you pull the jockey wheel up and tighten the clamp. Do you also need to tighten the clamp after lowering the jockey wheel when parking up for the night at a campsite or moving the caravan about?
8,358
Yes because if you don’t you will find it sliding and the nose will could get lower upsetting your levelling and placing additional load on the steadies. It would also be a problem moving the caravan on its mover or manually.
Clamp and be damned.
114
78
635
It always amazes me the large amount of vans I see pitched up on site with their jockey wheels raised off the ground leaving only the four corner steadies to support the van. Surely having the JW down would provide extra strength to support the front area of the van where people are sitting, or am I missing something? There's got to be a reason for it?
4,074
In reality it makes no great difference JW up or down when pitched on site.. There isn't a similar additional support at the back of the caravan so the steadies are enough to cope. Having said that, there is absolutely nothing wrong with adding the JW to support the A frame.
Reactions: RogerL
May 28, 2025
20
17
The reason I asked was that I had tightened the jockey wheel while moving the caravan with the motor mover, and I thought the jockey wheel wasn’t turning when I made a manoeuvre with the remote.
Jun 6, 2006
889
172
18,935
Perhaps the JW ears hadn’t cleared the slots the ears sit in when retracted, that would stop it rotating in the shaft
4,816
Most times we left our jockey wheel up only lowering it when about to hitch up. Occasionally if I remembered we would lower it so that it just rested on the ground.
Sep 4, 2011
376
172
18,735
If you wind the jockey wheel up there is more load on the front legs than the rear due tue the nosewight of the caravan. Perhaps people doing this is why some had bulkhead bracket screws shear off.
3,092
That's not an issue for the front legs - on site they may have to cope with eg 6 people sitting at the front and maybe a full water tank.
I always leave the jockey wheel down on site - no point in extra tasks to raise it and then lower it later.
376
172
18,735
As do in I as never seen any advantage whatsoever of raising it.
1,240
1,085
2,435
If you don't use the clamp the jockey wheel offers no support whatsoever. For travelling wind it up as far as it goes ensuring the two "blades" that hold the wheel locate in the two notches in the lower part of the telescopic tube then loosen the clamp and retract it up as high as possible into the A-frame and retighten the clamp. Ensure the wheel isn't touching/fouling anything underneath (brake linkage or A-frame).
When arriving on site wind it down an inch or two then unclamp it, let it drop to the ground and re-clamp it before uncoupling from the car. I find that doing this ensures there's enough travel both and up and down to level the caravan forwards/backwards when on the pitch.
When on the pitch leave it wound down. The more points of contact you have with the ground, the more stable everything will be.
Sam Vimes
2,319
1,847
The nose weight isn't relevant when you have the steadies down. Loading on the steadies will vary as you walk around the caravan anyway.
May 28, 2025
20
17
You hit the nail on the head — the wheel was too low, that’s why the motor mover wasn’t working properly. I thought caravanning was supposed to be a relaxing hobby, but I’ve been stressed for a week now. Heading down to Fareham beginning tomorrow.
Should’ve just stuck with a tent — this is crazy! All the stuff you have to do when you own a caravan... £20,000! I must’ve been hit in the back of the head when I bought this. In hindsight, I should’ve started with a cheap caravan. Pretty sure this isn’t for me.
Jan 20, 2023
1,240
1,085
2,435
It's just a learning curve. The jockey wheel is locked unless you lower it by an inch or so hence it won't allow the caravan to steer when maneuvering (as you've found out!). It gets easier each time, honestly. Stick with it, you will end up enjoying it!
Reactions: JOCKSERB
8,358
Even cheap caravans have a jockey wheel. I’m sure before too long any uncertainties will have passed and your stress levels will come down.
Oct 19, 2023
562
447
1,135
From an engineering perspective the front and rear steadies aren't quite the same on my caravan (I don't know if there's much variation between different caravans). The rear steadies are fixed to the chassis thus the load is spread over the length of the chassis (between the axle and rear steadies). The front steadies are fixed to the wooden floor. With the jockey wheel raised the front steadies are supporting the wooden floor which is then supporting the front chassis / A frame / hitch. With the jockey wheel down the chassis is supported by the jockey wheel which then supports the floor (in addition to the steadies). I don't know how much difference this makes but I always leave the jockey wheel down when pitched as I can't see any advantage in going to the additional effort of raising it.
Sep 23, 2023
1,082
413
1,435
Perhaps relevant information with regard to novice caravan users may be gleaned from literature published from the manufacturers, usually available to upload from their website,they may find the basics are if use.
