Just a little bit of a warning here for all of you that either of the Kampa Air Awnings.Mine is just over a year old now and has been used 5 times at the most.On our last short break I was convinced that the awning had gone down but looking on the bright side I thought well it must be I hadnt put enough air into it in the first place so I topped it up to make sure but sadly yes we had the dreaded leak fortunately after a full bottle of soapy spray and half an hour later I found the leak.Right for you Kampa Air Owners stand in your awning and look outward away from the van if you have the 390 between the big inflatables you have three air poles Left middle and right that can be removed it was the left hand one that was leaking the leak was right on the end of the plastic tube that is attached to what Kampa call the inner tube to me it looks as thought it had been vulcanised propley As luck would have it I rang our dealer and the Kampa Rep was calling there that day and replaced it under the so guarantee now all is good again. I thought I would post this to make you all aware
Sir Roger
Sir Roger
